Two questions about the Norvel .061 AME???
Thanks for helping out.
1. Where can I buy a glow starter for this thing? I have seen one that clips on but haven't seen it for sale anywhere. Any ideas where to get one of these things?
2. I ordered several props from Tower and some of them came predrilled with holes way to big for the Norvel. Specifically, I got several APC and a couple Zingers. The Zingers have the right size hole but the APC's are way too big. What gives? Are is there anyway I can use them? If not, what are you guys using? Thanks,
Dan
Dan
RE: Two questions about the Norvel .061 AME???
Dan --
Tower Hobbies (www.towerhobbies.com): search for part number MODP1158 -- the Model Products 1/2A Head Lite Adapter
Cut a short piece of large fuel tubing and slip over the prop screw - the length should be no longer that the thickness of the APC hub. When you mount the prop, the tubing will hold it centered until you can tighten down the prop screw. The APC's are aggregating with such a large hole -- one would have thought they would have matched the diameter of the recess in the hub with the diameter of the NORVEL spinner.
the "other" Andrew
the "other" Andrew
