Cox Needle Valve Extensions
WA
I've got the cowl on the Altair, and now I figured it's about time to decide on what I will do about a needle valve extension. Currently, the needle valve would need on the order of a 1" extension to reach the outside of the cowl. I'm thinking about having a welder I know weld a small wheel collar onto the end of the needle valve. But I'm secretly hoping that someone else might have a better and simpler idea. This is for a Cox TD .020, any thoughts?
Thank you!
Derek
Thank you!
Derek
RE: Cox Needle Valve Extensions
If you get hold of a copper nail or even a piece of brass rod from your LHS , file off the blackening on the needle valve and so lder it on.Or the cheaters way out, would be slide a piece of tight fitting fuel tube onto the needle valve and cut to the right length.
Ditto the latter. The clear vinyl tubing is stiffer, smaller in diameter but a little harder to install. It might be better for a 1" extension. This piece of silicone tubing has been working great since last August, however.
Ben Newkirk
Ben Newkirk
TN
STEP AWAY FROM THE NEEDLE VALVE EXTENSION!
Grind away the black oxide from the needle knob; cut the head off (and grind away the oxide) a 4-40 allen head capscrew and silver-solder it on the needle. Drill a small hole in the cowling for access with a ball-end allen wrench. Very precise adjustments can be done with no long extension to turn into a blur and destroy that precious Tee Dee needle housing! [X(]
I've done this on my .020 Stealth Bipe, the Twin Lizzie 2 and the Gyrator. All have the engines completely enclosed in radial cowlings and are very easy to adjust.
Here's a pic of the .020 needle in the bipe.
AL
What a great idea, DICKEYBIRD! I have one with an extension that I will cut off and convert to your method this afternoon. Thanks!
(Now if I can just keep up with that @!~$%*&^ allen wrench)
jess
jess
Gee, I usually use a piece of dowel, and a piece of fuel hose as a coupler. An alternative is to get some Gold-n-rod, cut the head off the needle and shove the plastic down over the stub. JB weld if required. The knurling on the rod makes for a good grip.
The original Killer Bees used this type extension because we could not keep a standard needle from vibrating out.
On my Hyper Viper, I drilled a 3/32" hole down the entire length of the needle shaft to lighten it up. Works great, no drifting, even with a Venomish front end and drilled venturi.
My Feedback: (50)
CA
Dickybird, that's GENIUS! Did you come up with that one all on your own?
When will the engine manufacturers begin putting a recessed hex in the ends of their needle valves??
Arlen
Arlen
TN
No, no genius here! Like a lot of the tricks I use, I can't claim that one as my own. I saw it in magazine article somewhere.
WA
Thanks for all the great answers guys. I think I'll be trying the Dickeybird's method first, we'll see how it goes.
Dickybird,
Are you using any special paints on those pop-bottle cowls, or just the regular rattle can? I'm planning on using krylon and a automotive top coat to make it fuel proof, but I am a little worried about cracking and crazing of the paint. Have you had any problems with that?
Thanks again,
Derek
Dickybird,
Thanks again,
Derek
TN
I used Top Flite LustreKote, warmed the can in warm water, shook the heck out of it and sprayed on a very light tack coat. After it dryed for 30 min., I sprayed on 3 more coats, letting each flash off. I let it cure for a week before getting fuel anywhere near it and so far, 25% hasn't damaged it. I do keep a paper towel handy when fueling to soak up any spills immediately.
