Glo clip for Norvel
My Feedback: (28)
MI
Glo clip for Norvel
What kind of glo clip will actually stay on a Norvel 0.74 during starting? While we're at it, is there a brand of glo plug wrench that readily fits into the Norvel head for easy plug removal?
Phil
Phil
My Feedback: (28)
MI
Glo clip for Norvel
Wouldn't the Cox glo head wrench remove the entire head? The Norvel plug unscrews from the head, doesn't it? I mean it does look like a standard glo plug, non-Cox type, isn't it?
Phil
Phil
Glo clip for Norvel
Nope, its special. The norvel head screws on to sandwich the glowplug in. The glowplug is like a top hat with a point on it. The plug died on both my .074 and .061 after about 45 min. to an hours use. Been ok since then. Others in the club havent had my problem. I run 40% power master.
Edwin
Edwin
My Feedback: (7)
glo plug
I use the same fuel as you do Ed but I add some oil to it I get about the same life out of a glo plug, have you tried the spiral lite plugs?, hey how about shoot me a pic of your delta, mine is finally deceased, But have not been able to find the plans from witch it was designed, it went like a bat out off heck, and roll was faster than you could count, Fastlash
Glo clip for Norvel
If you go to www.discounthobbies.net and click on the delta called superfly you'll see it. Mine is the one thats Texas flag on top, US flag on bottom. I know the shop owner and the designer is a member of our club. So when he said it was nearly indestructable, THAT sounded like a challange. Well, its not indestructable, but it IS very durable. I've got about 50 flights on mine right now. I've flown it in 20 mph winds. Not a bad little foamy. He has a superflea thats smaller with the same engine. A rediculously fast roll rate. I've also got the electric version. Its the only electric plane I've got thats enjoyable to fly, aerobatic, 10 minute flights.
Edwin
Edwin
Glo clip for Norvel
If you go to www.discounthobbies.net and click on the delta called superfly you'll see it. Mine is the one thats Texas flag on top, US flag on bottom. I know the shop owner and the designer is a member of our club. So when he said it was nearly indestructable, THAT sounded like a challange. Well, its not indestructable, but it IS very durable. I've got about 50 flights on mine right now. I've flown it in 20 mph winds, quite a challenge. Not a bad little foamy. He has a superflea thats smaller with the same engine. A rediculously fast roll rate. I've also got the electric version. Its the only electric plane I've got thats enjoyable to fly, aerobatic, 10 minute flights. No freebies for me, I was a paying customer.
Edwin
Edwin
My Feedback: (56)
MS
Sullivan's 1/2A Clip
I have the new Sullivan 1/2a Clip that connects to your ni-starter. It is very similar to the old Cox glow head clip. Part # M058. Less than $10.00! Check it out.
*rcnats*
*rcnats*
