cheap cox helicopter
Here's a huey wid a sure start on it for 19 dollars-
[link=http://www.hobbysurplus.com/gaspoweredtoys.asp]huey closeout[/link]
and here's just the sure start engine for fifteen bucks..
well, the site uses javascript so you gotta serf over to the cox engines.. they have props too.
[link=http://www.lonestar-models.com/cgi-local/Order.pl.cgi]lone star balsa[/link]
If you get the huey- be sure to break the engine in for real...
I searched forever for my similar .049 powered heli when the engine broke in in flight and flew into the hay field two pastures over.
RE: cheap cox helicopter
Lonestar Balsa is out of the 5x3's and the Sure Start. 049 for $15.00! I had a pile of them on order and I got a call today that said they do not have any and will not be getting any!![]
Later,
Tim
Later,
Tim
Actually, you can get really great performance out of those 'copters. Yes, a lighter body would be a good thing, I propose a "roadkill" profile of Foamcore, clearcoated with Oil Based Urethane clear.
THEN, cut the blades off near the root, and make new blades of 3/32" balsa about 1.5" wide and 12" long. Make some new little tip weights and balance them so they just fall forward at rest. Goop adhesive should stick the blades to the old hub parts.
You may just lose one of these in a thermal
