Glo Bee Plugs Question
I got a Glo Bee plug, to me surprise ( I didn´t know them) it has two parts and the coil isn´t in the same shape that in the regular Cox Plugs. What can you tell me about them and its performance ? Are they made for 1.5 volts. Thanks. Regards
Claudio
Claudio
RE: Glo Bee Plugs Question
The GloBee's were a hot little item. They produced more power than the TD Glowheads. I lit mine with a regular NiStarter. They are no longer available so enjoy it while it lasts.
TX
Nelson makes a GloBee type plug.
The plug will work in heads built for the Nelson HD or STD plugs and uses a screw in 'clamp' to hold it in the head.
The photo has the Nelson GloBee plug, the clamp, and a Galbreath Nelson plug head with the GloBee plug in place.
TX
A neat thing about the GloBee type plug is that they eliminate the hole that a normal element is wound in and thus clean up the combustion chamber a bit.
On the other hand, you have a 'flat' with a coil in it in the middle of the head. I am not sure if that hurts or helps the head design. Like many other things with 1/2A engines, the scale of the flat is much larger than it is in a larger engine.
GloBees also need a good starting battery and engines with a GloBee plug are sometimes more difficult to start than with a normal plug.
Finally, because the element hole is gone, the compression ratio is sometimes raised and you may need more head clearance to keep from being over compressed and pre-igniting.
Larry --
How do you like the Galbreath Head/Nelson plug combination vs. the standard NORVEL head and plug? Is it worth changing to Galbreath/Nelson from a power and longevity standpoint.
the "other" andrew
the "other" andrew
TX
ORIGINAL: Andrew
Larry --
the "other" andrew
Larry --
the "other" andrew
Since I mostly run VAs and Cyclons (both use Nelson plugs) I don't have current data on the new Norvels and the Freedom plug. Back when I was running the nickle cylinder AMEs I ran the Galbreath / Nelson set up and got more power than with the Norvel plug of that era.
I have a nickle Norvel .061 in an RC wing. It has the Galbreath / Nelson setup (I like the $3.25 and $3.15 Nelson plug costs). I will try a Freedom plug in that one and see what happens.
I guess I may have to breakdown, dig up the bucks, and try a Revlite .061 to get a current idea of how the plugs match up.
I´m glad to read that they are good stuff. It´s very hard to light them with a low batt, I tried a Ni Cd and nothing happened, but a fresh alkaline seems to work fine. Thanks for the information.
Claudio
Claudio
