Norvel .061 inverted runs poorly
Does anyone else have this problem? I 've had 2 Norvel .061,s and both of them loose rpm and kind of go rich when flying inverted. The thing will scream in all other attitudes. I do not have the problem with the .074.
Darren
Darren
TX
RE: Norvel .061 inverted runs poorly
Darren,
If it was a CL plane the most likely cause of 'rich inverted' would be a tank mounted to low below the needle valve.
I'm thinkin' our engines do not know whether they are pulling a plane controlled with waves or controlled with wires.
So . . . I'd say raise the tank and see what that did. And I would run a test on the ground by just holding the plane upright and then flipping it inverted.
