Norvel bigmig .15, glow plug?
WA
ordered one and it should be arriving today. Upon reading the specs, "Glow plug not included" I trolled their site to see if they recommeded any particular heat range and or brand of glow plug. I have a couple of OS A5's and R5's and a bunch of special order itialian Pico cold plugs. These plugs I usually run in my Paris modified itialian pico .21. I use the A5's (cool not cold) in higher elevations. Does anyone know what is the suggested plug for a small norvel engine?
RE: Norvel bigmig .15, glow plug?
WRX,
I have run both long and short (med heat range, I think) in my .15's for break-in. These were CL versions with non-idle bar plugs. I think I prefer the short plugs. The heat range allows you to vary timing with different fuel/prop combinations and weather conditions. Start with a medium, then switch to another heat range and see which works best with YOUR combination.
I have only run mine through break-in, perhaps someone will chime in who has used them extensively.
George
George
