If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 14 of 37 FirstFirst ... 4121314151624 ... LastLast
Results 326 to 350 of 913
  1. #326
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 1/2A trainer anyone?
    OK thanks, Andrew !!I` ve got an entry for your 1/2A contest.Check the postings.. I started a thread on it,Or am I too early?HOPE not!!! SEE YOU THERE,maybe..DAVE B.
    Dave B. ------ Corsair Brotherhood # 11-------
    I am a,#11,cause,,I`m 10% Better,than a perfect \"10\".
  2. #327
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I went "mental" at the LHS today..I got the RIGHT stuff BABY..I can see side by side the penalties ,that would have accompanied the larger equipment ,I was going to use..You can see it, on just the servos.. 4 micros are nearly the size of, 1 standard size servo.I haven`t done the math, but it`s a large weight savings..I`m a little upset that ,I buy a 4 channel radio "SYSTEM",and they only give you 2 micro servos in that "system".That kind of math doesn`t work for me..HOW many servos do you get if you buy a 2 channel system?? 1, or none..The other peeve I`ve got, is, with the reciever.I know what they are doing ,with the pin connections on the receiver is fine for the larger scale planes..It`s like the engineers forgot what they were designing this receiver for..What dosn`t make sense is that this is micro stuff,4 channel s but only 4 pin sets. Channel 4, is also the battery port.Again thats fine for the larger stuff but to do a 4 channel hook up, you have to buy a Y harness, and "T" the servo in, with the battery.So,right away you are adding weight, just so you can use, all the channels. .Wouldn`t it make more sense to just have a seperate battery port,instead of forcing a person who is obviously going to use a system like this ,for its weight savings?THIS could have been designed onto the p.c. board very easily....
    Bipe would you like to make up a drawing, for a servo tray, for the TRAINER .Or would you like me to come up, with something and then scan it before I put this together.I haven`t been doing much work on this, the last few days ,but I will,tommorrow again..
    1 other thing ihave 2 Futaba s3101 ,and,2 Hitec HS-81 .Do you have a recommendation of which servos`, where??...DAVE B.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	338785   Click image for larger version.
ID:	338786   Click image for larger version.
ID:	338787   Click image for larger version.
ID:	338788   Click image for larger version.
ID:	338790   Click image for larger version.
ID:	338791   Click image for larger version.
ID:	338792   Click image for larger version.
  3. #328
    mclintock's Avatar
    Join Date
    Feb 2004
    Fayetteville, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The excuse (reason?) the micro four channel rx now have only four ports and no separate pair of pins for a battery is because most of the market for those radios if for electric powered planes, and the rx will get power from the battery eleminator circuit in the electronic speed controller. Thus we micro gassers have to use the y adaptor or hack a servo lead.
    Thank goodness for the electric 3-d craze, the price and availability of itty bitty servos is amazing.
    Clint
    the preceeding may be false
  4. #329
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good stuff Dave! You are going to save nearly half a pound in radio gear, if you can believe it.
    I guess the radio manufacturers figure nobody uses the rudder and electrics don't use a throttle servo, so 2 servos are good enough. What bugs me is that nice little switch you bought which doesn't have a charge lead. If you have to unplug the battery to check it before each flight, then you don't really need a switch. I splice a charge lead into mine so I don't have to take the wing off to check the battery.
    The HS81s and the s3101s are comparable as far as the specs go, with the Hitecs being a little faster. I don't think it really matters which ones go where.
    Go ahead and make a tray and scan it.
    Bulldog Brotherhood #4
    1/2A all the way!
    Club Saito #151
  5. #330
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    .So WE, are the odd-balls then eh, CLINT..
    .Good stuff Dave! You are going to save nearly half a pound in radio gear, if you can believe it..
    .Yes ,just looking at these parts side, by side ,with my larger stuff,everything is nearly, 1/4th the size ..I can really,see how these things can make or break, a well built 1/2A plane,now..IT really is, DINKY little toy parts, huh...ALL I have to get ,for the kids, is the trainer cord now.KINDA had to go in to next years hobby budget, to finish off this years projects[sm=greedy.gif][sm=greedy.gif.Oh well at least the trainer, will be put together right,and I won`t have to go, to the school of hard knocks ,on this project..even got color correct tip ties .YOU didn`t notice,[] BIPER..
  6. #331
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A decent tray for push rods.I`m going to come up, with something else, for the pull-pull cable system
  7. #332
    Join Date
    Mar 2005
    Valentine , NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    I just received a copy of the Jr. Falcon, Jr. Skylark, and Ranger 42 Plans from Goldberg. I will be working on the Falcon first I think. But first I have to complete my 1/2A version of the Miss Bikini. I don;t have a digital camera right now but I will take photos of the completed plane and if someone is interested in putting the plans to CAD and posting here. I'll send them a copy of my hand drawn plans. The Goldberg plans will be mondernized to save weight.
    I broke my wrist getting thrown from a horse I was breaking so I'm a little slow typing and building.... But should complete the Miss Bikini in another week.
  8. #333
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowboy88,
    Check out Dave Fritzke's site. http://my.pclink.com/~dfritzke/ You can find an absolutley flawless CAD drawn version of the Jr. Falcon drawn by Gene Rock.
    I really like the Jr. Falcon. Here are a couple that I built with a friend's Falcon 56.
    1/2A all the way!
    Club Saito #151
  9. #334
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ..I don`t know what I did, to that tray I scanned before ,it came out GIGANTIC,sorry .Here`s my, sliding servo,servo tray..ALONG with threaded rod ends, and clevis`s,, It should be very easy, to set up the cables now...
ID:	339285   Click image for larger version.
ID:	339286   Click image for larger version.
ID:	339287   Click image for larger version.
ID:	339288   Click image for larger version.
ID:	339290   Click image for larger version.
ID:	339291   Click image for larger version.
ID:	339292   Click image for larger version.
ID:	339293   Click image for larger version.
ID:	339295   Click image for larger version.
  10. #335
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That looks good. Why do you have the sliding servos?
    1/2A all the way!
    Club Saito #151
  11. #336
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking ,I can balance (set) left, and, right cables, on each servo arm, with the threaded clevis`s ,and then the overall tension, with the slide .The sandpaper just keeps things from slipping once the nut,and ,washer are tightened (clamped),on the track.I thought this would help, take the Fuss, out of the set-up.Also for adjusting the threaded clevis ,I can slide the servo back, unhook at the,aileron/rudder horn, spin the cable,re-hook it,tension-up and check for equal lengths.If the servo doesn`t slide I wouldn`t be able to un-hook the lines, without undoing the servo arms from the servo to release the tension..Do you think, I`ve over engineered this ,Andrew???
  12. #337
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If it makes it easier to setup, then great. I was just curious. I'd be tempted to put a drop of CA on the clamp screws after it is setup to prevent them from backing out.
    When you setup the pull-pull wires, they shouldn't be so tight that you can't disconnect the clevis from the horn easily. You just want the lines tight enough to take out any slack, not tensioned like a guitar string.
    1/2A all the way!
    Club Saito #151
  13. #338
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I knew you shouldn`t be able to play a tune on the cables.I`ve not done, a complete set-up yet,but if I find that ,this is not necessary, I also have the NON-sliding pattern, for a servo tray here and will go that route.I`ll give it the "real-world ,set-up, test",and if it`s,NO help,I`ll change it...
  14. #339
    Join Date
    Mar 2005
    Valentine , NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HI Bipe,
    I looked at the link and wished I had seen it sooner. Then I would have saved myself a few bucks.... But I now have a set of CAD drawings and the "real thing" as well.
    The Miss Bikini is coming along great. I hope to have her finished in a couple weeks. I will be building two of these ships. One using the color scheme in the original article (it looks really hot!) and another using an alternate color scheme. I will be powering one ship with a Norvel 0.061 and the other with a Wasp 0.061.
    I kept the airframe outline of the original ship but altered some of the fuse construction both, to keep it simple and to use what I had on hand. The first ship uses ACE foam wings but the second will use built-up wings and the original airfoil.
    As for the jr. falcon, any pointers? I want to build a twin skylark as well using 0.061s. But I have a A-26K Invader I also want to build this winter. So I am not sure which I'll complete first.
    I'll share pics when I'm done with each project...
  15. #340
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On the Jr. Falcons that I've built I set the wing inicidence, tail and thrust to 0 and I added ailerons. This really makes it a great performing plane.
    Here's a video clip. http://www.missionwings.com/videos/JR%20Falcon.wmv
    1/2A all the way!
    Club Saito #151
  16. #341
    Join Date
    Mar 2005
    Valentine , NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bipe,
    Looks like a great flying little airplane. I've always been found of the falcons... I was thinking about setting everything to 0... Tell me how did you add the ailerons? Did you simply cut the T.E. stock or did you add a T.E. beam and use the T.E. stock as the aileron?
  17. #342
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cowboy,
    The wings and horizontal stab are sheeted foam with a balsa stick TE and TE stock for the ailerons. I took out about half of the dihedral.
ID:	339887   Click image for larger version.
ID:	339888   Click image for larger version.
    1/2A all the way!
    Club Saito #151
  18. #343
    Join Date
    Mar 2005
    Valentine , NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bipe, thanks for the info and pics....
  19. #344
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well I got a few things done on the trainer over the weekend .I`ll put up a few pics
ID:	340174   Click image for larger version.
ID:	340175   Click image for larger version.
ID:	340176   Click image for larger version.
ID:	340177   Click image for larger version.
  20. #345
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    THE bottom of the landing gear mount..screws used as clamps..I was thinking about velcro to mount the receiver and as a vibration isolator,opinions please or should that still be wrapped in foam??
ID:	340189   Click image for larger version.
ID:	340190   Click image for larger version.
ID:	340191   Click image for larger version.
ID:	340192   Click image for larger version.
  21. #346
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    wing servo mount ..How about the velcro concept???
ID:	340630   Click image for larger version.
  22. #347
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Velcro will work fine. A lot of guys use it for mounting receivers.
    1/2A all the way!
    Club Saito #151
  23. #348
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If I could just velcro the wing to fuse, I could avoid those stupid rubber bandsLOL I wonder if anyone ever tried that??
  24. #349
    Bipe Flyer's Avatar
    Join Date
    Nov 2002
    Mission, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some electric flyers hold their wings on with magnets.
    1/2A all the way!
    Club Saito #151
  25. #350
    D Bronk's Avatar
    Join Date
    Apr 2005
    Wpg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hmm HOW WELL DOES THAT WORK bipe???I`LL STICK TO THE RUBBERS.GOT THE DOWEL HOLES MADE ALREADY.. how about the velcro idea has anyone heard of that being tried..I kind of like that idea cause I`ve got lots of experiance with it ..THATS how I put my shoes on
    servo tray1/32" ply.servo blocks made from spruce,bottom sheeting 1/16" sheet ,.needs a touch of balsa filler ,here and there.
ID:	340943   Click image for larger version.
ID:	340944   Click image for larger version.
ID:	340945   Click image for larger version.
ID:	340946   Click image for larger version.
ID:	340948   Click image for larger version.
ID:	340949   Click image for larger version.
ID:	340950   Click image for larger version.
ID:	340951   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
