Building and flying the LST 1/2A Trainer
#657
TX
RE: 1/2A trainer anyone?
some more photos only need to cut rudder and will make the front top removable ( I`ll attach with servo screws), to make easy access. Patricio ( my youngest son ) posing with the 51 inches wing.
It´s my first scratch built model plane so Im anxious to finish and fly it.
#659
TX
Already cut, made hinge slots and covered rudder and stabilizer, no photos yet (`till I figure a trim scheme), also made aileron torque housing,those little details take time (since is the first time I make this).
#660
TX
aileron torque rods installed
Now some questions:
1.-Can I install the aileron servo on one side of the center ribs as not to weaken the middle joint? (this is not cutting a square space in the middle ribs but in either side of the middle?).
2.- Wich servo will do I have both futabas 3004 and hitec hs 88 I`ll use a .15 os max .15 fp. ( I know I havent weighed this thing yet).
Now some questions:
#661
If yo need to you can put it to one side, but you might get assymentrical movement between the two ailerons.
I'm not familiar with the HS88, do you mean HS81 or HS85 maybe? Either way, if it is smaller than the S3004, then use it.
#663
TX
I already made cuts for the HS 81, it´s shallower only I´ll add 1/4 of an inch hardwood to screw the servo and leave more rib area glued together.
fuel proofed the fuselage, made aileron hinges and slits.
#665
That plane looks great Cedillo, let me congratulate you for taking your son at such young age interested in this great hobby.
Good look on the maiden.
Saludos.
Saludos.
#669
TX
Cedillo-
Plane is coming along nicely, way to go
Just dont put skis on it or you will disapear like Dave
......saw Dave posted in Warbirds a week or 2 ago, I PM'ed him to stop by 1/2A & say hi....no response
#672
I don't think the windows are bad at all- if it were me, I'd add another triangle to the front window, starting from the existing front corner of the side window, and extending down, so that the rear side is as wide as the square window next to it.. Make sense?
It looks great by the way- I wish I could cover that well!
Jason
Jason
#673
Why did you not stack the ribs together to cut these out?
ORIGINAL: D Bronk
.I see how that tile GImo works now..I can`t do that with adobe...EX. horizontal stab.,is on three seperate sheets that have to be trimmed and taped too .. WHAT`S A FISKER?? NOT FEELING the greatest today but ,I`m pickin away at it ..D.B.
#674
Hi, I have an e-flite park 450 outrunner brushless and a 3 cell 2100 maH LiPo battery. I was wondering if this setup would work in the 1/2a LST. Thanks!
#675
OMG
I discovered this forum this evening and have been reading this thread for 2 hours, instead of going to bed, because i couldn't wait to get dave's review of this trainer. Now I'll be on pins and needles until we can wake him up somehow! All that hard work and that lovely lil plane. Mebbe a small excursion to Canada is in order......
I have always somehow been intrigued by the minute scale of 1/2 A aircraft, even tho all my buddies seem to think that the big stuff is much sexier. I am completely delighted to find you guys here.
