"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Norvel parts
Old 01-29-2005, 10:49 AM
mikegordon10
mikegordon10's Avatar
Default Norvel parts
I'm trying to find an older style Norvel .061 Piston/Cylinder assembly or even a complete engine. These are the silver ones. Any help would be appreciated.
Old 01-29-2005, 12:22 PM
Andrew
Default RE: Norvel parts
Mike --
The NORVEL site lists an [link=http://www.shopatron.com/product/product_id=NVL100406/100.0]AAN piston/cylinder set [/link] -- but I don't know if this is truly AAN or if the REVLITE set will be substituted. A phone call would probably verify which one is actually in stock -- the item is listed as available. [link=http://www.sigmfg.com/]SIG[/link] also carries parts, but their site is currently down at the moment --
You will also find new AAN engines showing up on thEbay -- there is a NIB A6R up now, item # 5953337306 that looks to be AAN -- color shift is a little bad, but the fins appear to be notched for the cylinder mounting screws.
Old 01-29-2005, 07:09 PM
mikegordon10
I checked out your link, thanks for the info. It said this was for a Big Mig .061. Ya think this is the same porting etc as the AME???
Old 01-29-2005, 10:02 PM
Andrew
Sorry -- didn't realize you were looking for the AME. The B6 and B6R P/C set is not the same as the A6 and A6R -- the porting will be different. Here is the [link=http://www.shopatron.com/product/product_id=NVL100402/100.0]link to the A6/A6R [/link] set. This set should be available also. Larry Driskill also carries NORVEL engines and may also have parts in stock on [link=http://www.kittingittogether.com]his site[/link].
