baby birdie servos
CA
baby birdie servos
hi all,
i have a global quality kits baby birdie that is waiting to have the electronics installed. i would like to know what servos i should use. i was thinking all hs-85 micro hitec servos?? what do you think? also i want to use the hitec 4-channel fm feather receiver and want to make sure it will work for futaba. it has a cox .049 with throttle and muffler in it. how will this perform?? is it enough?? i have an OS 10 just in case. i also plan on using a little 250mah battery to power the servos. what do you guys think??is this gunna do it?? all the info wil help! thanks
RE: baby birdie servos
I would use HS81 servos. They are more than enough for a Baby Birdie. The Feather receiver is the worst product that I've ever seen from Hitec, so I wouldn't use one. Hitec has started using "feather" to describe a lot of their products, but I mean the single conversion one with a red heat shrink case.
I think that your best value would be to buy a Hitec 555 flight pack.
http://www2.towerhobbies.com/cgi-bin...&I=LXUZ92&P=ML
It comes with a Hitec 555 RX, 3 Hitec HS81 servos, a 250mAh battery and a switch harness for under $100.
Try the .049 and if it isn't enough, put in the .10.
As an alternative, how about the FMA PS-10 servos? They don't put out as much torque as the HS-81 (12.5 oz/in vs 36 oz/in) but they weigh only .16 oz instead of .58 oz? They also have a 'universal' connector, but if that shouldn't pose a problem...
Just suggesting an alternative.
Bob
Bob
