COX Part
RE: COX Part
Ah the RR-1 tank....finding a new one is like finding hens teeth. The last one new I saw went for over $100.00 just for a tank. I can make and anodize a real pretty knock off using a vented 8cc tank but it still has the reed set up in it.
Later,
Tim
Later,
Tim
RE: COX Part
Thanks for the link to the Anodizer. I had an RR1 when I was in the AF, and it always impressed me as having far more power than any of the reed valve engines, and was a bit less sensitive on the needle than the Medallions. It also didn't start backwards. I'm curious about getting one of those little beauties he showed in his add. The rear disc induction (Not a reed valve) has been used in a lot of high performance engines over the years.
RE: COX Part
ORIGINAL: Tim Wiltse-RCU
Later,
Tim
Later,
Tim
Now to find the rest of the engine! Actually I also have a rotor but have no idea if it is a reverse rotation as was discussed in another thread by DeviousDave.
I need to try and get a better picture.
Robert
RE: COX Part
Robert,
It's pretty easy to tell the standard rotation drum. Looking at the front of the tank i.e. drum end. the hole in the drum for the crankshaft extension pin will be in the 5 o'clock ish' postion as the intake window opens on the standard rotation drum.
P.S. great job on bringing back a thread from the DEAD...I think this one is from 2005!!!
LAter,
Tim
LAter,
Tim
RE: COX Part
Tim ,I think you anodized a RR-1 tank for me . The one I took all the color off the outside. Engine has been long gone now .Thanks again ! I like to fix Dooling .29's now. NO colors to mess with & NO gaskets . Cost about as much as a Cox RR-1 though. Now trying to find parts for Ohlsson & Rice race cars . As bad as the wee ones . CYL, Max H.
RE: COX Part
Robert,
LAter,
Tim
Robert,
LAter,
Tim
As for bringing back a thread from the dead, my post could not be more relevant!
Robert
RE: COX Part
Of course with an intake set up like this you can turn the tank 90degrees counter clockwise and it will then run in reverse. The vent tubes are now at the top of the tank but you get my point.
LAter,
Tim
LAter,
Tim
