unknown cox
RE: unknown cox
Well it's not Cox that's all I know. The only beam mounted engines Cox made are the Space Hoppers and TD/Medallions. It does seem to use a Cox cylinder and head though. Most likely a home cast case from the looks of it. Oddly enough though it looks alot like the drawing I made a year ago for an idea I had about getting some cases cast for me right down to the webs on the front of the case. Is that moss growing on it
Later,
Tim
Later,
Tim
RE: unknown cox
It sort of looks like an Aurora with a different cyl and backplate.
Maybe it's a BSB .049
There is a drawing here about half way down the page. http://www.mh-aerotools.de/airfoils/cox_wanted.htm
RE: unknown cox
I don't know, the webs on the front of the case are to long for a K&B. Plus check out the lug mounts???? It would be easy for someone with the right tools to make a Cox look alike cylinder. I wonder if it's a reed intake or what it has going on there in the rear. BigChap is this engine over there in the UK?
later,
Tim
later,
Tim
RE: unknown cox
That engine is a Keil-Kraft "Cobra" .049 made in Hornchurch, Essex, England sometime in the 1960's.
I don't know how many they made but it was not up to Cox standards for performance so it is probably fairly rare and valuable today.
A lot of engines that don't measure-up have a tendancy to fall by the wayside...which means there are fewer around.
Clean it up and show it off.
