black widow running time
MO
RE: black widow running time
i guess i need to buy a gas tank then, any special to look for? i just built my first plane and have no idea what i am doing so is the tank just a container for gas or does it have some sort of pump or what?
I just want to see a black widow with its own tank. Not a separate tank but the one that comes witht the engine. I dont think mine came with a tank!
http://www2.towerhobbies.com/cgi-bin...p?&I=LXB439&P=
link to one at tower,,if your black widow doesnt have a tank,,its a killer bee or a product engine...check out the link and browse through tower for the other cox engines,,then we can help from there....Rog
samp615,
Assuming that you do have a Black Widow, inside the tank is a piece of tubing that can be adjusted to various heights for the type of flying you are doing. If the tubing is set high, you get the same type run whether you are flying upright or inverted. When you are flying, the fuel is thrown to the side of the tank so the tubing will pick it up. If you are holding the planelevel, you will run only half the fuel out before it stops. Hold your plane with the outboard wing down and it should run longer.
Good luck with it.
George
Edit: Oops, I was assuming a control line setup. If you have it in an RC plane, you need to remove the tank and adjust the tubing to the bottom of the tank. Be careful to not lose or pinch the small "O" ring between the tank and the backplate.
Good luck with it.
George
