Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
TYPE OF FUEL FOR A NORVAL
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 03-17-2005, 09:29 PM
fire@forthall
Default TYPE OF FUEL FOR A NORVAL
I AM RUNNING A BIG MIG 061 AND AM HAVING PROBLEMS GETTING IT TO RUN AT LOW RPM I AM RUNNIG A 4 STROKE FUEL AND IT RUNS GREAT AT FULL TROTTLE BUT DIES AT IDILE
Old 03-17-2005, 11:36 PM
jessiej
Default RE: TYPE OF FUEL FOR A NORVAL
What % nitro and oil is your fuel? What% of oil is castor?
jess
Old 03-17-2005, 11:56 PM
Bipe Flyer
Bipe Flyer's Avatar
Isn't 4-stroke fuel something like 16% oil? You need 20% oil with at least some castor. I prefer to run 20% all castor in my Norvels.
Old 03-18-2005, 03:18 PM
jessiej
I just received via Brown Elf, 3 quarts of Norvel fuel. It states an 18% oil content and says the oil is Klotz, but not what kind of Klots. I suspect Klotz Benoil. This fuel is stated to be manufactured by Sig Manufacturing Co. Previous Norvel fuel I have purchased was produced by Wildcat. The fuel is available in 15, 25 and 35% nitro.
I typically add a small dollop of castor to this fuel and have run it in Norvel, Cox, and a variety of older 1/2 as-OK, Spitzy, K&B etc.
jess
Old 03-18-2005, 03:45 PM
ptulmer
ptulmer's Avatar
I wrote Norvel and asked about the oil. The response I got was vague and irritating. His answer was "Klotz is synthetic". Well, one kind is I guess, but not all. It is no longer made by Wildcat. When I wrote them asking about the oil, the only response I got was they no longer made Norvel or Cox fuels. Even though their website still claims they do.
Needless to say my next bottle of fuel won't be Norvel...
Old 03-18-2005, 04:15 PM
Bipe Flyer
Bipe Flyer's Avatar
I got this response from Norvel.
Andrew,
Norvel fuel is a blend of castor and synthetic.
Best Regards,
Robin Stevens
>-----Original Message-----
>From: Andrew Donatelli
>Sent: Tuesday, October 26, 2004 9:47 AM
>To: [email protected]
>Subject: Norvel NVX Fuel
>I was wondering what type of oil is used in Norvel fuel. Is it castor or synthetic?
>Regards,
>Andrew Donatelli
Old 03-19-2005, 01:02 AM
ptulmer
ptulmer's Avatar
Still a little vague, but much better than mine! Wonder what the %'s are.
Old 03-19-2005, 01:26 AM
Bipe Flyer
Bipe Flyer's Avatar
Ohhhhh a little of this, a little of that.
Most fuel manufacturers are pretty vague on actual percentages. That's why I get Red Max fuel custom mixed from FHS Supply. You just tell them what percentages you want and what oil type and they'll send it to you in quart containers.
Old 03-19-2005, 02:04 AM
combatpigg
combatpigg's Avatar
Oil is the most expensive component, slightly more than nitro. The companies that guard their recipes are doing so because if they advertised the oil content, you wouldn't buy it. If they can tell you what the nitro % is, why can't they divulge what the oil is and in what amounts? You can't go wrong with RED MAX or SIG or FOX fuel because you will know what you are getting. Most of the time I buy cheap LHS 15% and top off each gallon jug with SIG caster. You should see the 15% burn in my AMEs or the FORA, that's all you need to have good performance and some fun.
Old 03-19-2005, 07:23 AM
SST
My Norvel .049s run fine on Byron 25% with 16% all castor, and the .074s run Omega 15% with 20% 50/50 oil.
Old 03-19-2005, 08:40 AM
flyinrog
What! no more Norvel fuel??.hmmm, I run Cool Power %20 anyway(topped off with castor oil) but whenever I get something from norvel I go ahead and get a quart of that %35 juice too....Rog
Old 03-19-2005, 08:07 PM
AndyW
Proper fuel is important for any engine. I've run many brands with various nitro contents and have never had any problems. Never have run 4 stroke fuel however. Can you not get two stroke fuel?
In any case, idling and throttling issues with the Norvel .061 and .049 has nothing to do with fuel. The issue is lack of some means to adjust the idle mixture. Do a search on my past posts for my take on the subject.
Do you have a tach and can you give us some top and bottom numbers? In other words, at what rpm WILL it idle at?
Old 03-19-2005, 08:58 PM
Bipe Flyer
Bipe Flyer's Avatar
I wont even use 4-stroke fuel in my 4-strokes.
Old 03-19-2005, 11:24 PM
ptulmer
ptulmer's Avatar
Hey Rog, did you know Norvel recommends NOT using Coolpower! Check the tech articles on their site. I'm going to put an order in to Red Max soon.
Old 03-23-2005, 12:43 PM
fire@forthall
sorry for the delay in a reponse. you know the work and play thing gets in the way of my play. the fuel that i use is byrons 4 stroke hei fuel with a 22% oil content both syn. and caster. i also use a 30% nitro this is the same fuel that i use for my saito .91. sorry for the delay but mabey you can help. this thing runs like a raped ape wot but i just can't get it to idle. thanks for the input
