.010 fun and games
.010 fun and games
I posted this some time ago but it's too fun not to post again. I never have done this myself.. must add it to the bucket list. Maybe with a Babe Bee instead of a precious .010 though!
[link=http://www.youtube.com/watch?v=ph2PMs2-7G4&feature=related]Flying shop rag[/link]
RE: .010 fun and games
Here are a few more .010 videos from YouTube for entertainment..
[link=http://www.youtube.com/watch?v=yAFk3oKcGNo]8 x .010 Spruce Goose[/link]
[link=http://www.youtube.com/watch?v=Yw0hEaA0mvc&feature=related]Page Boy[/link]
[link=http://www.youtube.com/watch?v=I_6ZZUHoPEY&feature=relmfu]Wow, some real airspeed here[/link][link=http://www.youtube.com/watch?v=dZldbTMXFn4]Powered glider, RC[/link] (acting like it needs hotter fuel)
[link=http://www.youtube.com/watch?v=YXsKsAOUyjY]Not sure, a Randolph design perhaps?[/link]
SC
ORIGINAL: MJD
That last one is a Skoots by Jesse Shepherd, Jr. Floyd Harp flys them at SMALL and sent me a plan from 1992, Aero Crafted Models in Bedford TX.
Skoots - that's it! I recognized it but the name and origins escaped me.
If anyone finds any other cool .010 videos please post them here. I guess .020's are okay, but I'd prefer .010.
That sure looks like the same plane in the video!
Here's a quick .010 from across the pond: http://www.youtube.com/watch?v=FTY4A...L2J7mSGJLTiPZQ
Several years ago, I scaled down a Randolph Pong Two and built it for a TD .010. I called it El Pongito(slang for Little Pong): http://www.youtube.com/watch?v=I_6ZZUHoPEY&feature=plcp
My trusty old LaStick when it was powered by a TD .010: http://www.youtube.com/watch?v=cf_ZFkhmXTw&feature=plcp
The same LaStick several years later with a TD .020: http://www.youtube.com/watch?v=5XgQhmv5s-Q&feature=plcp
Pilatus Porter with a throttled TD .010: http://www.youtube.com/watch?v=3Qkypvw81No
That Pilatus is something else! I thought the microlite throttles were fictional.
The micro Funjet is a hoot as well. Actually, they all are.
LA
ORIGINAL: MJD
Al
His video description of the Pilatus says it's a microflite unit. Steve's throttles haven't been available in quite a while. Goodness knows I bugged him enough about them over the years. I believe he had a machinist friend helping make those and is no longer in the biz, or some such folklore.
ORIGINAL: MJD
He either had a patent pending or was able to buy himself a full blown patent for this 100 piece device that does not pass ANY of the tests for what is patentable.
It looks like a Rube Goldberg contraption and after hearing all the hype it was a real, "let down" to see what it actually was.
In the end, was it basically a variable exhaust restrictor throttle? Or was there more going on?
Seems to me if it was a variable restrictor with a bit of internal volume, you could scam some tank pressure.
It looks kind of like a tiny piston ring compression tool...for assembling engines. It has a thin [tempered?] steel band that wraps the cylinder. The band [cumberbund?] has 90 degree bends at the extreme ends so that tiny [#2-56?] hardware can clamp it tight to the cylinder. There is bracketry that is involved with this hardware to facilitate a connection to a servo.
I'm over simplifying it, the actual drawing has an unbelievably high parts count. It has 10 things doing the job of 1, here, there and everywhere.
Beyond the hype...it is unimaginable that someone would go through the process to get this thing patented.
From what Al has said, you have 5 ozs max to play with for a sporty .010 RC model.
If throttle is a big enough issue, then a remote barrel valve would seem to be as simple a solution as any... but exhaust extensions probably hurt top end power.
I just don't understand the need.
we did this a couple of years ago using streamers also a touch and bounces off a picnic table with an electric slow flyer the engines faired a lot better. we were a little too low a couple of times, the flying engines for cox 049s martin
ORIGINAL: Tee Bee
