Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Aileron control throws on contest plane?
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 04-12-2005, 01:36 PM
propbuster
propbuster's Avatar
Default Aileron control throws on contest plane?
Hi guys, I'm wondering what to set the control throws on my contest plane at for it's maiden flight. This is the first 1/2a plane I'll be flying with ailerons. Low wing, two channel ailerons and elevator only. It's got a swept back Ace tapered chord wing with a span of about 36" The ailerons are 7/8" wide, and run the full length of each side. I don't want to over control, but want the thing to be able to turn too. I was thinking maybe 3/16" or a 1/4"? Thanks for your input!
Old 04-12-2005, 02:32 PM
BMatthews
BMatthews's Avatar
Default RE: Aileron control throws on contest plane?
1/4 total, as in plus and minus 1/8 from neutral, would be a good place to start. It'll be crisp but controllable at that setting.
Old 04-12-2005, 02:39 PM
combatpigg
combatpigg's Avatar
I 2nd that motion, it takes less aileron travel to fly than most people realize. I hate to "run out" of elevator on a first flight though, so if I'm gonna be fighting a touchy control on a test flight, I can deal with the elevator being a little bit jumpy, but it sure is a hand full when both controls are set too high.
Old 04-12-2005, 07:31 PM
propbuster
propbuster's Avatar
Thanks BM & CP, I'll go with 1/8" in both directions. I sure didn't want to snap roll the thing into the ground right off the bat! I'm sure it's going to handle a whole lot different than my Extra Easy high wing trainer. I can always dial in more throw after I get used to it if needed. That is, if it will fly at all!
