Cox TD Mounting Screws
What screw size does an .049/.051 mounting lug take? I would like to be able to use a socket head cap screw with a nut. All I can seem to find to fit is wood screws. I really dont care to be drilling out the lugs to fit a 4/40, or force one through. Any suggestions? Metric? Whats the best way?
RE: Cox TD Mounting Screws
Hey dude,
I've been having the same problems when some of the guys here suggested wood screws, although our engines are different thee mounting is still the same. all you have to do is add some wood glue to your screws before you insert them then just gently tighten them. You dont want to add too much weight to the front so avoide using metal.
I use 3-48's. 2-56's will work OK as well. If you are using screws rather than bolts, your LHS should have them, but you may need to look in the model railroad section.
Jim
Jim
http://rtlfasteners.com/Merchant2/me...&Store_Code=RF
You need it they got it,,,I bought a lifetime supply of screws for about $40, but most of them are for giveaway prizes at my funfly,,they dont sell the servo screws like you get from futaba, the sell the same size without the built in washer which is better because the "washer" gets in the way when you use them to mount a cox tanked engine...they do sell that type but in socket (allen) head type with the built in washer...real fast service too I got several hundred screws and box containers for my $40 would have cost at least 3 times that from the LHS..check it out..Rog
