.15 size 3d plane?
CA
.15 size 3d plane?
Does anyone know any 3d planes with will go well with a .30 four stroke? I already know about the mini 3d but i they are selling like crazy and i cant seem to get my hands on one.
RE: .15 size 3d plane?
Apparently the Mini Funtana works well with 30 four stroke. I bet that an Edgeling scaled up a little would work well. Do a search on Edgeling.
CA
That Edgeling would suit me well also. . What are the negatives on opperating these small engines, since i have no experience with them.
Well if my experience helps, the Edgeling is one of the best 3D performers my hands have built. Mine has a Norvel .74 but I bet that a scaled up one for .15 will be great.
Just put the most long prop you can with the least amount of pitch and the engine will be fine.
Hope this helps.
And don't forget to make it light.
Hope this helps.
It requires a little more break-in than a larger engine, has a special plug and should be used with fuel that has 20% oil with at least some Castor. It runs very well on 15% to 25% nitro. It has good ilde and throttle response and an excellent power to weight ratio. IMO it is just about the best engine for the money in any size.
