Depron plane
WA
Depron plane
Ok- I know it is not 1/2a, but it could be! Maybe an .020 would add a little more life. Seriously, I don't know if love or hate Depron yet, but I had to give it a try. It builds very quick, but also gets dinged up pretty fast. There could be some 1/2a possibilities here though.
http://www.rcuniverse.com/forum/My_f...2985797/tm.htm
Now that that is out of the way it's time to build a COMBAT plane! I see my Norvel twitching over there.....!
RE: Depron plane
Yes, I should say so! Pretty neat!! The way I've seen to curve the wing with little riblets on the underside will give the plane better performance than a flat sheet. And the curvature might make the wing stiff enough to go sparless? I have to show you a flat sheet plane the next time we fly, it is a ton of fun, but it doesn't like to be flown straight and level with .049 power. Now stop fooling around, and let's fly some combat[>:]!!
WA
RE: Depron plane
Ok! I look forward to seeing your 049 flat wing fly. It does have different characteristics. The riblet idea sounds good, but this 6mm depron is stiff. My LHS has 2 and 3mm in stock now. That would have worked better I think.
As far as the combat plane build goes I was going to use those rough dimensions you sent me, but with ailerons instead of rudder. And I found some of that film you used as covering for $2.00. Now that's cheap covering!
RE: Depron plane
The idea for the cellophane covering came from a guy who is a total guru around here, DAN RUTHERFORD. This is a guy who would be alot of fun to get involved with 1/2A RC combat, but he is one of those totally obsessed C/L stunt dudes who is always working towards that perfect score. That doesn't matter, if you can get MR CRANKY PANTS revved up, and with my Son [CHARLIE] coming in the first week in JUNE, we should be able to have ourselfs a pretty good day of streamer chasing and all kinds of ear splitting tunes to listen to with a speed plane here and there thrown in!!
WA
RE: Depron plane
I can't wait! Glad your son gets a break...look forward to meeting him. I will try to get Crankypants in the fight this time. And please do bring some screamers!
