Cox 0.049 old type reeds
Hi
I still have some old type Baby Bees with the old "star" shaped reed. The one that was held in with a circlip. Are the reeds from the present day 0.049 Cox motors compatable with these, i.e. can I replace my old reeds with the new type "oval shaped" reeds?
Richard
Richard
RE: Cox 0.049 old type reeds
Richard,
I dont think the new shape works to well with the metal clip type backplates, you will need to cut new reeds from shim brass. I have heard that floppy disk can also be used, havent tried it yet myself.
Stewart
Stewart
TN
The clear mylar reeds work great as a replacement for the old copper ones. Dunno about the newest stainless steel ones though.
My Feedback: (20)
OH
Hello Richard,
The floppy disc material seems to work. I have been using it since I found out about it and have not had a problem but, I have only been running my engine's in the 18-20000 rpm level. I use the current metal reed as a template and and cut around it with and Xacto knife.
Try it it's cheap.
Rick
Try it it's cheap.
Rick
MB, CANADA
I suppose you end up with an engine that will remember you ... I`m fonna try the floppy disc too, got a buggered star shaped one from copper...DAVE B.
Hi
Thanks for the feedback. I'll go with the floppy disk material. I see its a similar thickness to original mylar reeds. PLUS I was talking to our Chief Electronics engineer telling him I was looking for some floppy disks for the material and his replywas " oh so you're looking for mylar". So it seems the floppy disk material is not far off.
Made some last night and they seem to seal well.
thanks
Richard
thanks
Richard
