Norvel tank mount
ME
Norvel tank mount
Hi All.
Can someone tell me if the 1 oz. Norvel tank mount can be taken apart? I'm thinking of using one with a PAW 55 diesel and assume the clunk line is not compatible with diesel fuel.
TIA. Dennis in Maine.
GA
RE: Norvel tank mount
Dhanson, a friend (flyswatter) has one. Stick around, I'm sure he'll pipe up. I don't remember being able to take it apart, but I'm sure there's a provision for fixing the fuel line.
GA
Bipe, I've got that one too. And they're darn nice. You can do just about any manuever you want till the tank is dry. But like the one in the picture, the little vent thingy pops out and is easily lost. The bigger one has the same little vent.
the bigger one has a push button tube on top for a filler vent and yes it comes in two pieces, the problem is once you cut a hole out big enough to mount the inner half,,(on 1/2a planes) theres not much firewall left to mount the tank,,it mounts like the dragonfly motor with the same screws holding it on also hold it together...Rog
yes it is a regular clunk and fuel line too
its not missing, its not on that kind of tank (good thing you have beer for an excuse) the extended tank has a vent post,not curved (like the pic above) but straight up, AND a spring button to push when filling the tank and a flexible clunk line and it is in 2 pieces so if could remove the line easily....Rog
GA
ORIGINAL: flyinrog
ORIGINAL: ptulmer
No beer dude. Both my smaller ones had the little post! It's on all of'em that I've seen. You can't fill it through the vent tube without it. (can't take it loose from the engine either)
ORIGINAL: flyinrog
ORIGINAL: nanavion46
I don't see these Norvel tanks on their website. Just where do you get one? Thanks.
[link=http://www.shopatron.com/product/product_id=NVL102200/100.0]Extended tank part # 102200[/link]
[link=http://www.shopatron.com/product/product_id=NVL102100/100.0]Standard tank part # 102100[/link]
