Little Spitfire
Little Spitfire
This ones electric, but I thought you guys might like it. It's a little Spitfire that friend of mine designed and built. It is really cute and flies nice. It has a Jedelsky style wing, a 180 motor and A/E/T control.
Here's a link to the power system. Motor, prop, ESC and battery for 20 bucks!
http://www2.towerhobbies.com/cgi-bin...?&I=LXFAH8&P=7
Here is a video clip of the maiden.
http://www.missionwings.com/videos/Paul's%20Spitfire%202.wmv
RE: Little Spitfire
Bipe, is this Paul's new and improved version or old pics of the prototype? The original flew great... right up until the sheet balsa wing collapsed. Just a little bit more strength in the wing and this bird would have been a champ. And if this is the new and improved version then great!
RE: Little Spitfire
This is the new and improved version. Stronger wing, nicer shaped fuselage, canopy and a larger spinner. The old one was a little sensative on the elevator, but this one is very smooth.
Here's a picture and video clip of the original, for comparison.
http://www.missionwings.com/videos/Paul's%20Spitfire.wmv
RE: Little Spitfire
Jedelsky is similar to SWR. It is a wing made of two sheets of balsa joined at an angle to create undercamber and then sanded to an airfoil shape on top. Sometimes ribs are used underneath.
RE: Little Spitfire
Here's a little plane he built with the same power system. I'm trying to convince him to enter the 2006 design contest.
http://www.missionwings.com/videos/Paul's%20Parasol.wmv
RE: Little Spitfire
ORIGINAL: Bipe Flyer
Thanks for the video and pics.
RE: Little Spitfire
CP,
Paul's been flying a bit of pattern and buying a bunch of the big Great Planes ARFs, if you can believe it.
Andrew,
I think you're right, it is quite fast. The high wing plane in the other video is about the same weight with the same power system, but has a built up flat bottom wing and it is much slower. The seam acts like a spar on the Jedelsky wing.
Andrew,
