1/2A Spad plans
1/2A Spad plans
does anyone have or know where to get 1/2A SPad plans, ive tried spadtothebone.com but all theirs are for bigger sizes any help would be great
RE: 1/2A Spad plans
Someone here or that dropped by a while back played with 1/2A spad designs and his general feeling was that they were too heavy to fly well as I recall. Now if you were to get the very thinnest (3 or 2 mm?) coro and design to suit the material I think it would work well. But so far no one I know of has come up with any really decent high performance designs. Certainly the usual chop-chop designs do not translate well to smaller sizes.
RE: 1/2A Spad plans
I agree on the weight factor. I've done some experimenting with coroplast, and the standard 4 mil stuff you can find from old signs just won't work. 2 mil stuff might work out better, but it's not generally available unless you order some from a supplier. Now, there's a type of foam board with a thin papered skin on it I've seen in the craft stores that I'm going to try out.
RE: 1/2A Spad plans
Its not made of coro but Crazyherbs cheap delta is as close to the spad way of building that you can get. Find it at www.crazyherb.com. It flies great too.
RE: 1/2A Spad plans
ORIGINAL: flying poodle
......but Crazyherbs cheap delta is as close to the spad way of building that you can get. Find it at www.crazyherb.com. It flies great too.
Like FP said, it flies pretty well (especially for a $3.00 plane).
TX
RE: 1/2A Spad plans
Can't remember who, but a guy made a lttle bipe from styro meat trays & some balsa, we figured it could be all meat tray but the firewall... I'll try to find the thread
[link=http://www.rcuniverse.com/forum/m_3237386/mpage_1/key_/tm.htm]http://www.rcuniverse.com/forum/m_3237386/mpage_1/key_/tm.htm[/link]
That may be more modeling than you want to do, but the construction medium & techniques could be used on a spad design... and oops, the DR1 is a triplane, not a bipe
