"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Norvel Engine FAQ
Old 02-08-2014, 02:32 AM
  #526
Mr Cox
Mr Cox's Avatar
They call it a "fuel jet" but there is no parts # for it, what I can see. Just contact NV and hopefully they can help you out.
Old 02-09-2014, 02:39 PM
  #527
tbone4343
found it at nv its on its way and all is good thanks
Old 09-09-2014, 11:17 AM
  #528
DaveyMo
Looking for a bit of help here. I'm having some difficulty registering and ordering from the NV Engines web site. Is the site up and running, and is NV still open for business? Thanks for whatever enlightenment any Norvel-head can provide.
Dave Mo...
  #529
DaveyMo
Dave Mo...
Old 09-30-2014, 06:29 AM
  #530
DaveyMo
As a follow-up, I was able to contact NV Engines and place an order. The email I used for Alex was [email protected]
Dave Mo...
Old 07-16-2019, 07:27 PM
  #531
Pond Skipper
Pond Skipper's Avatar
For posterity of ye ole Norvel. AME .061
Fact a non modified AME series engine will work with a tuned pipe:
Published on Aug 10, 2015
.061 AME Norvel on a Profi Tuned Pipe
Non SPI version with 150 deg exhaust timing
APC 4.2x4 2oz of bench running prior to first flight
In the hand best peak 24.8k / 96F summer day
Best level pass 28.6k from down wind. 108 mph pitch speed.
12oz all up weight 5ch plane with flaps
88sq. in 28in span
Old 07-17-2019, 02:14 AM
  #532
N1EDM
Very cool. Thanks!! She sure must have been a handful!!
Old 07-17-2019, 06:03 PM
  #533
AndyW
I used a YS ( Chinese) tuned pipe with no change to the engine and got an extra 2K over the stokc, muffled engine. When it came on the pipe, the sound was AWWSOME.
Old 07-17-2019, 09:01 PM
  #534
Pond Skipper
Yes I have a CS .8 to 1cc pipe could try too the Profi pipe is similar to it very light weight a bit more dia. can recommend.
Here is a bench run of my set up shows a bolt on sportwerkz header worked out very well with the Norvel and AP .06
Really the prop is too big to run on the pipe statically but needed to know how the engine would handle the load of
the beefy APC 5x3 after the flight test with the 4.2x4 I was looking at more thrust potential.
Published on Aug 13, 2015
Reads from 23.5k average to best 23,740 rpm using a audio tach. 16oz thrust / 68 mph pitch speed / .18 HP / 134w
4.8k - 5.2k idle noted after the review with settings dialed in for lower readings using the RPM app.
Old 07-17-2019, 09:08 PM
  #535
Pond Skipper
And the AP with a bit longer MRP for best static on the ground.
Published on Jun 13, 2015
AP .061 Wasp on a Profi 1/2A tuned pipe with a Sportwerks header pipe.
Best noted peak 26.3k rpm / engine is new and has about 3oz of fuel ran thru it.
APC 4.2 x 4 / 122w / 99.6mph / 10oz thrust / 20% castor 25% nitro. Spins a APC 4.5x4 at 23.47k
And flight vid to confirm unloaded results.
Published on Jun 28, 2015
Skorch Flying - AP .061 - Profi 1/2A Tuned Pipe Best pass noted so far 24,793 rpm on the pipe APC 4.5x4 / 94mph
Tuned pipe length set for 25k unloaded (9.8in) from center of the convergent cone to the piston face. 5ch plane 11.8oz less fuel.
Static peak 22,609 rpm / .136hp -102w / 9.3 oz thrust / 86 mph pitch speed.
Old 08-07-2019, 07:45 AM
  #536
gmeyers
gmeyers's Avatar
Red face What's up
What 1/2A engines are folks using for sport flying now that Norvel, and Cox TeeDees, are out of the picture ?? Mos folks I know are using old versions of those engines but they will eventually wear out/die out. It's hard for a company to start up these days in competition with electrics so I suspect their probably won't be anyone new come along. !/2A diesels are popular in Europe and the U.K. but they are a tough sell in this country. Will Brodak small engines take over ? They will have to have their supplier up their game a bit. CS of China has the expertise, manufacturing capacity and ability to take over this market but will they ? How about your thoughts?
Old 08-07-2019, 01:49 PM
  #537
aspeed
aspeed's Avatar
Cox International still sells the Cox stuff and reproduces some of the easier stuff. Norvel Engines are still sold under the NV Engines name. I can see the days being numbered though. An OS LA .15 here is $140 at the hobby shop.here. Profi and Fora make .049s and .15s and some others. They are very good and really not crazy expensive considering the rising OS price, and the better Russian/Ukraniaan designs and quality.
Old 06-23-2021, 03:34 AM
  #538
H5606
I cannot find an address for this company and wondering if anyone ordered new products (June 2021) from NV Engines (formerly Norvel) and if so, what was your experience?
Old 06-23-2021, 09:18 AM
  #539
aspeed
aspeed's Avatar
Here's the website. Don't see an address on there. Airplane engines Never dealt with them, heard different stories, most, but not all good, some delays etc.
H5606 (06-24-2021)
