CG for Cox 182 Skylane
Hi Guys, I found an old foam Cox Skylane with out any engine or gear in it. I'll have to make a new firewall too as it appears that someone tried to glue the original back in and used some kind of glue that ate up some of the foam Does anyone know where the CG would be for this model? Thanks!
My Feedback: (14)
RE: CG for Cox 182 Skylane
Wow- great find. I have one I got from a yard sale for free, no radio, but had the original Cox engine in it with metal backplate. Fun little plane to fly. I balance mine on the spar. Hold it up to light and you should be able to see it. You'll need all the throw you can get out of the rudder, and a good bit out of the elevator too.
Let me just step to the basement and measure it up. I have three flying right now, one OEM, one Norvel and full house controls, and one electric with 4 channel. Trust me on this, while it is an OK plane with just 2 or 3 channels, it does a clark kent -> superman thing when you bring modern controls and a powerplant to it. I use a Norvel .061 with throttle, HS55s for ailerons, rudder, elevator and brakes, and HS50s for flaps and throttle. Ailerons do something dramatic for this plane but flaps are where the magic happens. I have never a plane that responds to flaps like this one.
Here is a thread on the one I converted:
http://www.rcuniverse.com/forum/m_30...tm.htm#3093854
Give me a few to go measure the CG.
Great looking 182 subarubrat! It must be a blast to fly with full house control too. I'm going to stick with the original two channel set up as I have an older futaba attack ll radio set looking for a home. I've got a Sure start .049 to put on the front and think I can fit a 1oz tank right behind it. On the fire wall reconstruction, does the original have any right or down thrust angle to it? I've fabricated one to fit but will wait to hear back from you before epoxying it up. Thanks [8D]
2.5 to 2.75 inches back is where mine are at. I have one that is flying with the original engine and radio and yes it will fly well but it is like night and day. If you do fly 2ch I would suggest making a pack from AAAs, you can place it behind the tank and get good balance.
The plane can handle the speed, it is actually a fairly slippery design. Of course it won't be very scale at that speed. The speed range is very broad on that model. I normally fly the norvel at 1/2 throttle, with the flaps up and the engine at full it really has a warbird like performance. With the engine at it's lowest idle and the flaps down it is very parkflyer like. I looked at my OEM one and it appears to have pretty much centerline thrust angles and I can tell you that my norvel and electric fly awesome with no down or right thrust.
Do you have a cowl for it?
ORIGINAL: subarubrat
