Hey, anybody got..
GA
RE: Hey, anybody got..
Rog, if I'm not mistaken, what Deadstik is offering is the same as a Golden Bee. I've got an extra 8cc tank you can stick right onto that Babe Bee and then get Tim to do his magic. Instant "Golden Bee". Since I'm already sticking the covering in the mail tomorrow... I've got some Babe Bee's here too. (they're too big to make tie tacks)
Actually, the tank extender will work without leaking if you go to the auto parts store and pick up a small bottle of Permatex Aircraft gasket maker. Good stuff, will seal around the extender if you apply it carefully before bolting it together.
GA
Clint, I "think" the venturi is smaller than the black widow and they're single bypass. Basically, it's a Babe Bee with the 8cc tank. At least, the one I ebayed the other day was. (sorry Rog!) Stunt tank. Is that the metal tank with the opposing vents?
GA
I guess that particular feature is for control line when the pickup is on the side? Hey, neat! You could do inverted c/l flight! Huh, I've got sooo much to learn.
Heck yeah baby, inverted cl! That's how you get un-dizzy, just go the other way for a few turns.. just gotta remember down is up.
I'm sure you noted that nearly all control line planes either have flat plate wings or symmetric, seldom flat bottom or clark Y.
Well except for the plastic cox things, with scooped plastic undercambered wings.. but they don't have stunt tanks either.. those don't count..
ptulmer,
Actually, you can go anywhere in the hemisphere created by the length of your lines. For combat, the guys chase each other everywhere. For stunt, the quest is for five foot radius square maneuvers. Actually a five foot radius would have to be completed in milliseconds considering the length of the lines and the speed of the aircraft...but it's something to shoot for.
Notice I say hemisphere, because the lower half of the sphere is off-limits, but some of us occasionally try anyway.
George
George
Quote by George:
"Notice I say hemisphere, because the lower half of the sphere is off-limits, but some of us occasionally try anyway."
I don't think I ever really knew the other half was off-limits. That explains a lot of the problems I was having in U/C long ago. I thought the ground was just getting in my way !
Those were some fun times for sure. That and having your fingers hurt because they were so cold from the wet fuel and such. Then having those already sensitive fingers whacked real good and proper when a motor kicked back[:@] !!!
Robert
Robert
ORIGINAL: ptulmer
And no, I'm keeping this one to use in my son's first CL plane this summer or next.
I was susprised at how peppy and easy to finger start the golden bee was after I put the right cylinder back on and cleaned the dried fuel from the tank, put new reed on, gaskets etc.. This one I bought along with a medallion from the same guy, and he had swapped the jugs, so my (rog's) golden bee had a throttle ring double bypass on it too! Until I took it back off anyway. I believe that throttled cylinder came off the medallion, as they were sold like that.
I was especially impressed about how non-sensitive the needle setting was for the freshened-up golden bee to maintian a smooth run.
Something about the small venturi I guess. It makes me wonder how a texaco compares.
It's stuff like this that makes me wish there was a comprehensive history of Cox engines with explanations of what the designers thought they were going for with each change and exactly what some features were on engines I only looked over at the hobbyshop!
For instance, I've long wondered what the "synchro pilot throttle" was exactly on the Pee Wee powered Ryan ST-3 that pre-dates the .020 restrictor ring thottled Pee Wee of the very late 70s. The box showed a three line control handle with a trigger! Was there spring return throttling on that Pee Wee or was it just third line for releasing the plane from a hold down tether so you could fly alone? Back then I was a teen and couldn't afford to buy one to find out and had a had a .020 powere profile Lil' Wizzard to fly off the patio in back of the house.
