Insatiable Need for Speed!!!!!!!!!
#126
I recently bought another one of these out of the case just 4.4g full range RX
No antenna wire big plus. Used with the Nano X at speeds to 147 mph PS,
zero glitches. I have some micro metal gear servos on tap will weight out
all the components prior to installing them. 4 servos / 220 mah LiFe 6.6v
1 oz tank, Engine not sure low weight Norvel .061 with header pipe and
Profi pipe has been tested few years back see vid.
.061 AME Norvel on a Profi Tuned Pipe Non SPI version with 150 deg exhaust timing APC 4.2x4
2oz of bench running prior to first flight In the hand best peak 24.8k / 96F summer day Best level
pass 28.6k from down wind. 12oz all up weight 5ch plane with flaps 88sq. in 28in span
Minimum break in time small prop helps to loosen it all up faster.
1/2A Skorch AME Norvel / Profi Tuned Pipe 108 mph
