1/2A spinner?
1/2A spinner?
Any of you guys know of a supplier that would have a 1 1/4" spinner that would fit a Norvel engine (.061). I have tried Tower and Novel and a few other places with no luck. I dont care if it is a plastic or aluminium.
1/2A spinner?
Mr. Hook,
Do you mean something like this? It's 1-1/8" dia. Try giving Cox a call, ( they have a toll free #) ... You'll need the hub too.. and when you get the hub drill it out with a 1/8" bit...
1/2A spinner?
1.5" is OK but for the small nose of this little plane "Miss Norway"
The 1 1/8" or the 1 1/4" would help with the lines.
Check out one of my planes on FMADIRECT.COM. It is the FW190 located way down in page under Customer Talk.
call toll free...
Cox Hobbies.. 800- 451- 0339
Ask for the Slipstream Jet spinner, and the backplate ( hub) you won't need the stud unless you'll be using it on a Cox engine. It's threaded 5-40
1/2A spinner?
There is a conspiracy by U.S. manufactures not to produce any spinners smaller than 1 1/2 in. dia. However Flair in England makes 1 1/4 in. in five colors. See if Radical RC will get some for you--the new U.S. distributer
