Selenium II
Selenium II
Here is what I have been working on for tooooo long... I call it the "Selenium II" Scaled up (125%) of the model I took to the indoor at Little Rock SMALL last year.
TD.010
11cc Perfect tank with modified vents
Rudder / Elevator / throttle
4 gram blue bird servos.
Battery (depends on CG)
GWS Rx.
Span.... 26" Chord.... 4.75" Aprox 120sq. in.
Wheels... Peck Polymers 1.25" #PA100
Colour... Balsa.
Present weight 4.2 oz.
TD.010
GWS Rx.
Colour... Balsa.
GA
RE: Selenium II
That is way nice mr. Skali. How much area, dimensions, etc. I may like to scale one up for an 020. Please let us know how it does in the air.
RE: Selenium II
Hi Bipe... I am having my 2nd childhood.... I was a child in the '60's.
This one must have come from an old mag that I was checking out when I was about nine. If you look at the first pic, the plan, the cabin has a port hole for the rear occupant ...... Circa '56 or '57.
Hi CP...... Now a TD .010 Pay load is indeed food for thought.. Wonder if DARPA would send a research check.
Perhaps a Payload contest for any size might be an idea???
