Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
small plane / glider for micro diesel?
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 03-16-2006, 04:38 AM
microengine
Default small plane / glider for micro diesel?
I have just ordered a tiny pb 033 diesel engine. I would like to instal it into either a tiny learner plane or good looking mini glider (ideally without a top engine pod).
I would appreciate any advice as this is all a bit new to me. If you have any links for suitable kits / manufacturers I'd be greatful....
Also some pointers on which micro radio gear would be handy
Thanks!
P.S powerplant:
http://www.peterburford.com.au/
Old 03-16-2006, 05:24 AM
vega
Default RE: small plane / glider for micro diesel?
How about a West Wings RF4 http://www.flairmodels.co.uk/Aircraf...s/Fournier.htm
or an Orion http://www.flairmodels.co.uk/Aircraf...n_electric.htm
both are set up for electric power but really easy to convert to diesel.
cheers
Jon
Old 03-16-2006, 07:59 AM
microengine
Thanks. They both look like the style I'm after, however they are a touch too large. I'd prefer something 40" or so max, so it's easier to transport and better suited to my tiny engine.
Anything like this but scaled down?.....
Old 03-16-2006, 08:31 AM
flyinrog
If your the building type, look at the top sticky on the page and make a 1/2A trainer!! read some of the posts as I think there are a few changes throughout the reading..its 40" WS..Rog
Old 03-16-2006, 08:40 AM
SGC
microengine,
How about a 1/2A Playboy, its 42"Span, be a nice gentle flyer on the PB diesel.
Stewart
Old 03-16-2006, 09:32 AM
microengine
I've built a plane already so plans are ok. I also don't mind ready made kits either.
Old 03-16-2006, 09:35 AM
microengine
I don't suppose there's anything caron fibre based at this scale?...
Old 03-16-2006, 09:44 AM
flyinrog
Micro the problem is this size in glow/gas/diesel isnt that popular so no carbon fiber....this size is mostly electric so its mostly foam and balsa....Rog
Old 03-16-2006, 10:11 AM
mr_leffe
Micro..... What did you build for your PAW? Have you flown it yet?
Old 03-16-2006, 10:41 AM
microengine
I don't have a PAW. It's a pb 033.
I built a plane years ago, but never flew it. It was a symetrical wing with zero dyhedral, for an OS10. I'd probably have crashed it if I tried!
Old 03-16-2006, 11:00 AM
MJD
MJD's Avatar
Spirit of Yesteryear makes a number of laser cut kits for small scale old timers, which should make real sweet (and relaxed!) flyers on the diesel.
http://www.soy.on.ca/
However, they seem to all be a little over 40" in span, i.e. 1/2A size. What about making a 2-piece wing? Not hard to do, just a little improvisation is required.
An airplane that comes to mind from my yesteryear is the Tomboy. IIRC there are two versions, a 44" or so and a smaller 36" one. I think you can get the plans from Bob Holman plans service, and I am pretty sure the one plan shows the 36 and 44" versions. It's a classic cutie, very basic in layout, and flys like a champ. I think you need a model of about 36" in size for that motor. Unless it's a bipe of course, then smaller.. ;-)
Small diesels are fun. I have a Pfeffer .036 (I think it's .036, maybe .033 or .03 - no documentation came with it) I picked up at Toledo somewhere in the later '80's.
MJD
Old 03-16-2006, 11:11 AM
mr_leffe
Wow.... You have one of those Rolex that looks like a model engine.... If I had one it would be in a glass box with Infa red security beams and get kissed g'night every evening.
Have you run It?
Old 03-16-2006, 11:53 AM
microengine
I only ordered it yesterday, after researching the options for 48 hours! When I read about the histroy and craftmanship that goes into it, I just HAD to own one. When I placed my order and payment was processed, I was given the opportunity to add a comment on the forum / feedback section of the pb site - mine's the latest one - Paul.
(P.S it's more like a Zenith El Primero, in fact. Rolex buy in a de-tuned and lowered spec of the El Primero movement, even on their top Daytona model. Rolex is more about the label, than pushing the frontiers tbh).
Old 03-16-2006, 12:12 PM
mr_leffe
Thats nice.... I would go for a Harrison MK VI myself, but my watches come with my 3 pack underware.
Old 03-16-2006, 01:25 PM
BMatthews
BMatthews's Avatar
If you don't mind building from plans there's lots of options avaiable for downloading. Some may require a little bit of modifying to suit the engine if they are originally intended for electric or similar but the sky is the limit for types of designs. Check out the sticky thread for Free Plans Links in the Scratch Building forum area. Another good source of small and simple plans that could be adapted is www.smallflyingarts.com and www.theplanpage.com .
I'm putting the finishing touches on a smaller and very basic to build powered glider that you may be interested in. It's in CAD so if you like I could send you a scaled sized to suit your .033 engine. Right now it's 60 inch span but it would be easy to scale it down to around 40 inches for you.
As for radio gear for an engine of this size I think it's safe to say that the smaller and lighter the better. Just be sure to get on of the more expensive full range micro recievers.
Old 03-16-2006, 03:13 PM
microengine
Which kits or ARTF kits (maybe with foam wings?) are available for this small diesel power? Any large online stores?...
Old 03-16-2006, 06:24 PM
Sneasle
your first link is bad BMatt
Old 03-16-2006, 07:05 PM
BMatthews
BMatthews's Avatar
ORIGINAL: Sneasle
Typo fixed... thanks Micro, if you really must stoop so low as to use foam then any of the slow flying GWS kits would be approgriate.
the horror, the horror...
That engine would look SOOOOOO nice on the front of a mini old timer with about a 36 to 40 inch span and tissue covered with clear dope.
Old 03-16-2006, 10:45 PM
Sneasle
welcome.. i figued out what it was, but might as well let ya know
Old 03-17-2006, 03:17 AM
microengine
At this stage I want to look at all the options before I make a decision. I may in fact get two models; an ARF trainer to get going quickly plus a really nice kit which I can spend ages building, ready for the next stage.
I agree either plane should be slightly retro, or t least very plain looking. A plain white powered glider would be nice, as would a real retro plane.
Don't worry, I won't be putting it in a day-glo thing covered with graphics!
Old 03-17-2006, 03:30 AM
microengine
I know what you mean about clear dope on some retro balsa. I built a tiny freeflight exactly like this many years ago. I even had a cox 010 ready to go in but I never got around to flight.
These sort of designs might look ok...
http://h1071118.hobbyshopnow.com/pro...p?prod=EFL2050
http://www.gwsus.com/english/product/airfly/j3-f.htm
http://www.houseofbalsa.com/e/env/00...=products:k-60
Old 03-17-2006, 01:53 PM
BMatthews
BMatthews's Avatar
Micro, being located in Jolly Ol' England there's only one possible patriotic option for you and you'd be a filthy scum sucking turncoat to avoid it....
[link=http://www.rcgroups.com/forums/showthread.php?t=321524&highlight=tomboy]Vic Smeed's Tomboy[/link]
Old 03-17-2006, 04:04 PM
microengine
Thanks. It looks like it was designed to lug a damn great HEMI around. I only have a nano diesel, with the power of a spent gnat. Plus it does look a touch, err, odd.
Old 03-17-2006, 05:18 PM
microengine
I've now spent two days looking for a model online. I think I'll get an ARF for now as my spare time is very limited for the next year (buying a house to do up). I'll probably buy a proper kit for next year. Anyway, for now this looks like the best one: 4 channel, 38", simple scale good looks, probably all in white with no colour at all.... whay do you think?....
http://h1071118.hobbyshopnow.com/pro...p?prod=EFL2200
(Might loose the wheels to save mass)
Old 03-18-2006, 05:59 AM
microengine
HOLD THE PRESS!
I think I've just found the perfect thing for my little pb engine. It's retro, ARF and very lightweight.... StarLITE. My only concern is it's only 3 channel. I wanted to learn on a full 4 channel really.
http://www.rcuniverse.com/product_gu...fm?kit_id=1126
For tech specs click on "backyard & park flyers", then link to StarLITE here:
http://www.iflyherr.com/cgi-bin/dpsm...nuF.html?E+Hrr
From above:
3 Channel R/C
Wingspan=36"
Area=261sq."
Weight=3.5 to 4oz.
Wing Load=2.3 to 2.6oz/sq.'
This kit includes the finest Laser Cut Parts, Hand Selected Balsa Strip Wood, Wheels, Carbon Rod Landing Gear and Pushrods, Tissue Covering, Full Size Plans, Motor Mount Parts and Instruction Manual.
The first flight was made using the 9v lithium pack and lasted 1 hour 25 minutes. The second flight was made with a 9v lithium pack and lasted 1 hour 47 minutes. There was still plenty of battery capacity left at the end of the flight and the maximum flight time with this battery pack has yet to be determined.
Average flight time using the 7 cell 50 mAh Nicad Pack is 5 minutes.
Average flight time using the 8 cell 50 mAh Nicad Pack is 7 minutes.
So what do you all think? Better than the Cessna above for my engine? The StarLITE is 1/3 of the weight so it must be better for my low-ish powered diesel, right?
