cox sure starts?
RE: cox sure starts?
That about sums it up!
The surestart is a good 'bang for the buck' but by no means a precision crafted engine. The piston to rod fit is sloppy and most need to be reset to give a good running engine. They are simple, easy to find parts for, and a lot of resources here on RCU if you need help. They would be considered a disposable engine. In fact I have even bought the surestart just for it's glow head to use in my other cox engines (its sometimes cheaper than buying the head seperately) and thrown the rest in a box. In the right hands they can be modified to give 'lively' performance.
i have recently bought one of these engines and your right they are damn cheap, if anything breaks on them you dont have to worry about finding/buying replacement parts, you can just get a whole new engine.
i have looked about a bit on these forums and there are a couple of things to look out for that i have found. when you get it open it up and as the other guy said check the fitting of the piston rod. also check that there are no metal shavings in there. basically give it a once over to check that nothings wrong with it. to be honest though you just cannot argue for the price.
Max,
A good plane to start with is the SIG Skyray. If you build from scratch, anything about that size is OK. The 1/8" sheet wings are simple to repair when (not if) you crash.
The radial mount on the Skyray is set up for engines with a tank. For the Sure Start, I would suggest two options. First choice: you can add some square hardwood spacers to accommodate the choke tube. Second choice: You can remove the needle, remove the choke tube, and reinstall the needle. This will allow you to mount the backplate against the firewall without spacers (but you lose the ability to choke it).
You will also need to supply a tank. Check out the thread on making a film canister tank. Or get a small metal one, if available.
To start with, you can get dacron control lines and a handle as a package at most local hobby shops. I THINK Sullivan and Cox both make them. You can also use Spyder wire or similar fishing line as control lines. About 30' is good for this setup.
As someone mentioned, you might consider getting two engines to have a spare glow plug, if nothing else.
George
George
Don't forget to check out the models at www.blackhawkmodels.com
He has a bunch of the Musciano (I just know I butchered that) style 1/2A hollowlog planes. They're pretty neat.
ORIGINAL: Clean
Hollow logs are set-up to use engines with tank mounts. Although I have mounted a tank inside the "log" back in the fifties, it is a bit difficult. You need to take the engine and landing gear positions into account to bring the fuel tube forward, and also make provisions for the fill and overflow.
For a Blackhawk models product, I would recommend a profile such as the "American Boy" as shown in the thread about finding an old plane.
The Brodak Basic Trainer is another one.
Of all those, I would still recommend the Skyray, with controls in the trainer position.
Just one opinion.
George
brED,
If you are making it CL, if you set up both nacelles the same way, most start the outboard engine first so it should quit first.
If you are converting a rubber or electric ship to wet RC, remember to provide enough strength for the extra vibration.
If you are converting to a twin FF, good luck.
George
George
VA
Yes, she was a rubber bird, but it (will) looks too darn nice to just wind er' up and toss around, so it'll be an R/C ship. I have started on the wings already and sheeted about a 1/3 of it and filled with polyurethane foam, but it's still kinda flimsy on the tips. I've never built a gas P-38, should I place a single tank in the center pod or one in each wing?
Thanks.
Thanks.
ORIGINAL: brED
Thanks.
Thanks.
George
VA
George,
Perhaps you know the kit, it's a Comet. Bought it a few years ago and had it sitting around since.
My plan from the start was to sheet it all with 1/16" then give it black and silver monokote. To keep the weight down I was going to tediously sheet between each stringer[], like they say to do in a Guillow kit. Really what I'm trying to do is get everything straight now, so I have a good plan to follow. I'm sure you can relate
