Cox Sure Start .049 vs Brodak .049?
I´m curious how the cheap little Cox Sure Start .049 compares power-wise to the Brodak/CS .049? It´s obvious that the Brodak is nicer in some ways with the beam mount and muffler, but I´m curious on how the they compare purely performance wise. They will be used in some 1/2A C/L stunt profile trainers (Stunt Chimps).
/Erik
/Erik
RE: Cox Sure Start .049 vs Brodak .049?
With the Sure Start, If you disassemble the backplate, drill the venturi out 11/64th's then you will find that it really performs. I am using a stock head along with stock everthing else and my last tach reading was 17,000 rpm with a cox 5x3. It is giving more rpm now after I sorted the compression out with head shims, but I can't find my tach. From memory it was giving 15,500-16,000 rpm before the mod. Not too bad for a $7.00 engine.
