Airframe for .26 FS
AB, CANADA
Airframe for .26 FS
This may not be the right place for this , but i thought you guys could help me out . I have an OS .26 FS that is looking for a home . I would really like to put it on a Bi-plane , but am having problems finding a decent ARF or kit . I would prefer an ARF , but would consider a kit , or ready built airframe if someone has one for sale . If anyone has any links they could provide , it would be MUCH appreciated .
RE: Airframe for .26 FS
I have an Ace simple series Ultimate biplane kit that I got an os .25 fp for,,it is a kit though and I havent even started it..some say its too much eingine, some say its just right,,I'll just have to see...World Models makes a few kits for .25-.30 size engines...Piper Chuck does alot of that size modeling..I think he is a moderator over in the Begginer forum...check with him...Rog
That engine is really at it's best in a slow flyer style of model. Don't be tempted to go with anything that has a heavy build or it'll be just too lazy and lack snap to it. That ACE simple series with the sheet fuselage and relatively heavy foam wings is like that IMHO.
It's a shame that you want it to be an ARF as there just are not many ARF parkflyer style of bipes out there. And not even that many kits. But if you are willing to consider a simple to build plan then there's a couple of options
My Feedback: (12)
SC
Piper Chuck also wanders over to the 1/2 A forum regularly, but usually just lurks.
Sportsman Aviation used to make a Waco bipe that might have worked ok with this engine, but alas they stopped importing it. You might be able to find it in outher countries under the brand name Jamara. There's a Tiger Moth available from Pacific Aeromodel that's listed as .30-.40 four stroke. A .26 might be ok for slow flying. I've seen it flying, I believe with a .30 and it was nice. If you're willing to give up one wing, World Models makes a really nice .30 size Piper Cub.
AB, CANADA
ORIGINAL: BMatthews
My Feedback: (12)
SC
How about scratch building a Pitts? I'm not sure how much power an OS 26FS has, but this one has a Saito .30
Build Thread http://www.rcuniverse.com/forum/m_3382269/tm.htm
Video Clip http://donatelli.net/pittss2s25/Pitts-S2S.wmv
If you'd rather build from a kit, then there's the Herr Pitts.
http://www.iflyherr.com/
[link=http://www.iflyherr.com/][/link]
If you want an ARF, there's the Wattage Pitts.
http://www.hobbypeople.net/gallery/128439.asp
[link=http://www.hobbypeople.net/gallery/128439.asp][/link]
AB, CANADA
Andrew , all i can say is WOW , NICE WORK !! You definitely have some building talent . I wish i had the time , not to mention skill level to take on a project like that . You have some beautiful planes Sir . [8D] You seem like a guy to ask for a recommendation of which way i should go . How much is involved to adapt a glow engine to a plane that was designed for electric power , and will it hold up ? What do you know of the Herr Pitts , would it be a good kit ? I realize my options are limited , and i don't mind paying a little more for quality , if the quality is there . What is your recommendation ?
If you read through the build thread on my Pitts, you'll see some discussion on the Herr Pitts. The Herr kits are top notch and as good as any I've seen.
Here's a link to a good discussion on converting the Wattage pitts, on RCGroups. [sm=eek.gif] http://www.rcgroups.com/forums/showthread.php?t=197858
Rog mentioned the ACE Simple Ultimate earlier. It is heavy for its size, having a plywood sheet fuselage, but it is a really good flying plane. Not a lazy flyer, but very aerobatic and nearly indestructible.
I'd suggest that the Wattage Pitts is far too small for the weight of the OS26. A relaxing flyer it would not be.
The plans I had in mind for you has turned out to be either too small or too large. It was the Fred Reese design that came out as the Doppledecker for an 049 to .19 and later in a larger version as the Golden Oldie for a 40 4 stroke. Sorry, I seem to remember it being for a 25'ish engine.
HEre's a pic in any case....
AB, CANADA
I really appreciate you guys taking the time to provide me links and ideas on which way to go with my project .[8D] So far it is looking like the Herr Pitts kit might be the way to go , unless Bipe Flyer is interested in making a copy of his little BEAUTY .
Yes, the planes I posted are fun, but you have to fly them all the time. No time to relax.
Bruce,
Are you thinking of the Golden Oldie 20?
[link=http://jinrunko.notlong.com ][/link]
[link=http://jinrunko.notlong.com]RCM plan number 1267. [/link] It was kitted for a short time just prior to Fred Reese's passing.
I built a pair of them. Wonderful plane designed by a master. Designed for a 20, but I put a .40LA in one and a .35FP in the other. I changed the airfoil to semi-symmetrical, but they can take off at 1/2 throttle and still float around as slow as you please.
It'd be perfect for a 26FS. In fact, that's what Fred used in the prototype.
Here come some more video clips
http://www.missionwings.com/videos/Andrew's%20Golden%20Oldie.mpg
Tail gunner's view.
http://www.missionwings.com/videos/Video%20Chase.mpg
Bruce,
Tail gunner's view.
Here's one that I almost bought for my Saito .30 - an Easy Built Models Waco. I haven't seen the kit, but it is designed by Laddie Mikulasko, so it should be good. It's on the upper limit for your .26, size wise.
http://www.easybuiltmodels.com/erc19.htm
So there WAS a mid sized version. Thanks for finding that Bipe.
That would be a great small field and close in sort of model. And you'd be surprised at the maneuvers you can do with just a rudder and elevator. As it is the model would be mild to sporty but add about 1/2 inch of dihedral per panel and it'll be mild to WILD with rudder rolls, loops, immelmans, split S's and other things galore.
LA
ORIGINAL: Bipe Flyer
"Parts are printed on the wood and must be cut out by the builder."
I thought that went out with buggy whips and button top shoes.
al
ORIGINAL: Big Al-RCU
Did I read this right?
al
al
ORIGINAL: BMatthews
No problem finding it. I keep the April 1999 RC Modeler in my "favourites" box.
In the build article there is one with ailerons on the bottom wing only, and another with ailerons on both wings. The plans call for ailerons on both.
