Sure Start add on's?
1 Post
Can anyone tell me if a texaco or golden bee tank assembly will fit onto a "plastic backplate" $7 surestart? I just want to be able to have a complete engine/tank unit. I will be fitting the assembly on a pusher propped model, so if there is a cox part number for the tank assembly, preferably somewhere that sells the tank assemblys, pusher props and they don't rip my pocket for postage to UK.
Andrew
Andrew
TN
RE: Sure Start add on's?
All the various reed .049 engine tanks will fit the SureStart engine. Dunno where you'll find a new tank kit for sale. You should be able to find plenty of them used though....in the U.K. as well.
GA
Yep, I bet Skaliwag will do everything he can to keep postage down for folks in the homeland.
One thing I haven't seen mentioned here is the lack of a thrust washer on the Surestart. You're gonna have fits with that thing in pusher mode. A thrust washer can be added, but you need to remove some material from the front of the crankcase. I have just waited and let the starter grind it down and put a fiber washer in... Either way, I just wanted to point this fault in the SS out.
1 Post
I read thru the FAQ on cox stuff for a start, I read about the thrust washer thats needed, I have a load of berylium/copper washers of various thicknesses that will slide in nicely. I had a look around but I can't find any tank assemblies ( the larger 8cc black ones ) or even shops selling them at sensible prces, much less 5 or 6 X 3 pusher props. I could always run the motor backwards and lose a bit of efficiency with the standard ccw prop. Even Cox-Estes don't seem to be selling them.
SGC, "Tileprint" is great, best $15 I spent, the "Dracon" is going to get some parts cut tonight and assembled over this weekend ONCE I HAVE CLEARED THE LITTER FROM MY BENCH
Andrew,
My sons Dracon used a Cox Blackwidow and a Grish white nylon 5x4" on backwards and ran the motor to suit . I fitted the motor with the opposite hand spring starter- old style that hooks the prop. maybe you can dig 1 of them up somewere they are the best thing to get a cox going.
Stewart
Stewart
