Can you start a Blackwidow with a starter?
My Feedback: (54)
PA
I have a cox blackwidow without the spring on it. Can I use my started with it that I use for 40 and 60 size planes without hurting the motor?
Good fuel hot battery and good compression they usually start very easily by hand place Yr finger close to the hup when flipping usually a couple of flips will do it same for norvel .061
he's right, but...
Hey Ryan,
Skypup is right, seems like the 1/2a's really hate a unfresh battery, and so long as you get the right amount of prime, a good plug with a good 1.5V across it it will lite right up with a good firm toss.
But...
Most guys around here use either a dedicated 1/2a type starter or a regular 12V one with little to no trouble. I just heard about a insert for a regular starter that will enable you to use the little spinners that come with our engines.
You just have to be careful of one thing!!!!!
If you have to much prime in the engine, you'll crack the rod. Seriously, you know how if it doesn't start after a few tries it will kind of lock up. Well if it locks up like that and you hit it with an electric starter you're liable to break it.
Hope this helps.
As Always,
T-theprole-
But...
Hope this helps.
As Always,
T-theprole-
Hey Ryan...
Joe Beshar, I believe, had an article a while back on how to
build your own 1/2A starter. It was much like a commercially made starter I had for my Medallions back in the early 70s. I sure started them up with no sweat. You might try e-mailing Joe with a query if you're interested. His e-mail address is listed in AMA Model Aviation magazine.
Ryan,
Yep, by hand is usually the best as the guys say above. Grampaw mentioned the Joe Beshar starter article and I built one and it works great, so long as the prime is right and the glow battery is fresh.
Will
Will
Hey Will...
Do you remember what issue Joe's article about the 1/2A starter was in? I want to find it but if you know the issue it would save me a lot of time pulling mags out of the cabinet. I've got the 1/2A bug again, and I may need a starter myself.
I heard this a while back in this forum:
If you are going to use an electric starter, get it up to speed and release the switch. Then bump the engine. The momentum of the starter should be enough to turn the engine over several times but it won't damage the engine if it does get flooded.
