Norvel .074 head and glow button needed!
Hey guys I need to get my hands on a Norvel .074 head and glow button. They need not be pretty, the plug can be blown. Really I would perfer a blown plug. No since in messing with a good one. The fins on the head can be ratty I don't care. If any one has one they can part with let me know what you need for it.
Thanks guys!
LAter,
Tim
Thanks guys!
LAter,
Tim
RE: Norvel .074 head and glow button needed!
Tim,
I cant help with supply of either , but it sounds like your going to fit a turbo plug into the head button. If that is so you should be able to turn up a blank button to suit, there identical in shape to an 061 button just the flange is larger in dia, 061 13.6mm flange,074 15mm dia.
Hope this helps.
Stewart
Hope this helps.
Stewart
I only have the one that's on my engine, but if you can wait a little I'll take some measurements with my digital calipers and crank out a drawing later today.
Also, the flange is slightly thicker on the .074 over the .061. 1.47mm vs. 1.31mm.
Shall I make a set of drawings for us? If I start that, I might as well go on and do a complete set for the entire engine. If youse guys want 'em, I'll do 'em!
