Q-Tee Build Thread
#101
RE: Q-Tee Build Thread
Well, the suspected weak point in the construction has indeed failed; I caught a wingtip on landing and snapped a couple of the struts. I'm sure the fact that's it's a tad overpowered with the Wasp and I fly it wayyyyy beyond it's original design had nothing whatsoever to do with it.
Long story short; the Q-Tee is about to become an S-Tee
#102
ON, CANADA
1 Post
ORIGINAL: digital_trucker
I have an orignal from the kit Airtronics Gere Sport here that I am wanting to fly. It looks like it should have ailerons. Anyway, I am glad to see the Q-Tee is still in regarded in some circles. It was a winner when it came out and time hasn't changed that.
Cheers!
#103
I believe the struts are spruce. As far as the dihedral goes, I'm not totally sure. Somehow when I built it I wound up with about 2/3 the dihedral that the plans call for. Hasn't mattered to the Q-Tee in performance or flyability, but I don't know what's going to happen when it gets S-Tee-ized. I may wid up doing surgery on the wings and turning the trailing edge into ailerons.
#104
ON, CANADA
1 Post
Would you recommend the Wasp? I miss the availability of Norvels and consisitent Quality Control. Are the Wasps hit and miss or is the QC consitent?
Good luck, John
#105
Despite the fact that it has less dihedral than called for, the Q-Tee has showed no lack of stability or rudder effectiveness. I don't really think there will be much problem with it shoulder-winged.....we'll see I guess.
The Wasps won't compare to a Norvel, but they seem to be fairly consistent from what I've heard. For sport planes they ought do very well. On the Q-Tee it's certainly PUH-LENTY of power. This thing is actually one of the fastest planes in the air around here! Keep in mind mine isn't totally stock any more; I'm using a turbo plug head on it (OS P8 plugs) and a Flyquiet pipe. It takes nearly a quart of fuel to get them to running consistently, until they're fully broken-in the throttles tend to be a little twitchy (they die at idle easy). It's very reliable now. I last run this engine back in october, and it started up at the first bump of the starter and I didn't have to mess with the needle at all.
#106
ON, CANADA
1 Post
Thank you for addressing my questions so specifically. I have wanted to buy a Wasp and will now that you have provided well thought out remarks and experience to reinforce my decision. The break in procedure and results you describe ring true.
I will often enlarge or reduce a model, in essence to make it compatible with the power supply. I have admired SR Batteries Cutie which looks like a 1.33% enlargement and refinement of the venerable Q-Tee. I am doing a 48" span for an OS.10 and an E version for an Eflite 10. I think they will be winners. Here's hoping anyway. I'll let you know how they work. These Q-Tee Cutie models in 36 or 48 inch are a welcome change to the more challenging models That I do find "More Challenging." I need to get out more.
John
John
#108
I am a big advocate for the Q-tee's. I've had 2-4 at all times. Started back in the 80's with .049's. Although the old motors are really not available anymore don't hurt my feelings. I've modified most q-tees to electric and there fore a smaller fuselage as I don't need all the room. I never thought I'd say this because I'm a nitro guy at heart, but electric in a q-tee is much more enjoyable. They are lighter and much more powerful. I only modify the front of the fuse, all other parts are same size as original. I think orginally the front of the fuse is about 3 inches square. I made it about 2 inches square and about 2 1/2 inches longer from the wing foreword. That allows better balance for the lighter motor. If I was capable of hovering, it would do it and take it straight up, yet goes very slow with throttle. I've also made a wing with ailerons. It did fly good but was not as enjoyable and easy to fly. I use it in our club competition fun flys and it does very well. No wheels, just bounce it off the ground for touch and goes. I've been flying for 35 yrs and I still fly them all the time.
What do you mean by spoiler?
#109
One other change I've done is change the dihedral. I think the planes call for 3 inches under one wing. I change that to about 1 1/2 inches. I use that as a standard now.
#111
Q-Tee with original dihedral works well as a rudder only aircraft and as 2 channel rudder and elevator aircraft. I have flown both modes, first as single channel with auxiliary step sequential throttle (quick blip Low - Medium - High back to Low) on a 1970's vintage Golden Bee with exhaust throttle ring and later with 2 channel digital proportional with same Golden Bee unthrottled. Q-Tee is excellent in both modes and the Golden Bee ample power with a fun factor. However this was without ailerons using rudder for turns, dihedral helped it to roll in turns. Later I put a Norvel .061 Big Mig (unthrottled) on it as 2 channels, really became fun to fly.
You must be having a real blast flying Q-Tee with ailerons. I still have to repair mine from the last crash, but I'm thinking about upping the ante with a 1964 OS Max .10R/C (only 3.1 oz. with ganged exhaust baffle plate for idle back pressure and no muffler. Engine is same loud as an unmuffled Cox .049 on full throttle, but sounds muffled at half and less. This is not Schneurle, is an earlier lower power cross scavenge with baffle dam on top the piston).
#113
Wow, a trip down memory lane!
I started first in 1967 with a Goldberg Skylane - escapement. Crashed immediately after about 15 ft.
Then a Mambo Special in 1968...ditto, but at least it made it high enough to hit a water tower....
Then an RCM Trainer....one flight.....
Then finally a Q-Tee in the 70's. 2 channel only. Success! Loved doing flat spins!
Then on to a Sig Kavalier for my first "full house" plane, in about 1978.
But the next plane was an S-Tee. Fun, but not as fun as the Q-Tee.
#114
Interesting, Ted that you'd mention the Q-Tee was more fun, because I'd think it was the other way around, but Q-Tee is a blast to fly in its own right. It is about as simple as you can get, but with the generous tail control surfaces, is capable of quite a bit of fun. I finally powered my rebuild after 20 years with a Norvel Big Mig .061 CL/FF version (no throttle). It really moved out and became truly fun. About the only step up (in my opinion) is to Lee Renaud's Gere Sport biplane (about the same wingspan, same type construction).
#115
I suspect that the fun factor was higher for the Q vs the S simply because the higher wing would make the roll couple from the dihedral more effective. So likely the Q snapped around with more vigor than the S. Ted that sound about right?
#116
Probably very true. And it might have something to do with it being my first plane to actually return home with me (many times!) with no damage!
#120
#121
Q Tee Build Thread
My previous post showed my collection in a very cool space. But now, since I have the room, I'm gearing up to build a purpose-built toy room. No cars though, but about everything else.
Starting out with 2900 sq. ft. and nine foot ceilings. I will put in a bathroom, two bedrooms, shop and bar. The rest is open to imagination. I will be "imagining" for a while...
So I started by painting the ceiling black. Already positioned the pool table in between the posts.
Next up will be the bar top, a circular "Beetle-Kill" piece, 10 ft. OD, 6 ft. ID, 3 in. thick. Finally, one big room with minimal walls. The rest will be photographed as I progress. Here's the space I am working with:
GallopingGhostler (12-25-2020)
#124
My QTee...
Since the maiden I have moved the CG back and reduced the dihedral. Flys better as a result. QTee was the very first RC model I built in 1976. This second one is much better built!
combatpigg (12-25-2020)
