VA .049 MkII RC
VA .049 MkII RC
Finally I got around to test running this engine, and wanted to pass along what I've observed so far. Yeah I know they're not available anymore (curses..) but there must be a few out there.
Conditions: frikkin' cold, about 20F, and windy. Hiding on the deck to stay warm but determined to run the darn thing.
Fuel: Cox Super Power fuel, because I had a couple of new cans and it seemed a good choice for break in runs.
Prop: 5-3 Cox rubber ducky (black) because I haven't made APC prop bushings for it yet and this is the only one that fit the prop screw snugly for centering.
Plug: Nelson HD
First run - running in a rich two cycle, 17,800 - 18,000.
Second run - a bit leaner, 18,500 - ish. Throttled down to 9k fairly reliably, transition a bit rich and stumbly as expected, I haven't tweaked the air bleed yet either, need a few more runs before I feel compelled to do so. Setting seems close though.
Third run - running steady and happily at 19,200 or so. Peaked at 19,800 for a couple of seconds then I backed off again. throttling improved a bit.
Fourth run - similar, kept it at 19,300 or so, a couple of quick excursions to flat out at 19,800- 19,900. Motor richened up fine after peaking, back to 19,200-19,300 and steady.
Fifth run - screw this, my hands are freezing. Another time!
Engine still has squeeze at TDC, so seems I haven't wrecked it yet..
So far I like it. A bit heavier than the AME 061, but seems to have pretty nice manners. Start easily by hand, easier with 1/2A electric starter of course (Speed 600 with prop adapter, push button and rubber hose drive cup, on 12V spins the motor plenty fast!). Due to air temps hand starting cold was a bit stubborn.
Does anyone have comparable data for an AME .061 ot TeeDee or? Yeah I know a FORA will spin the blades off..
MJD
Plug: Nelson HD
MJD
RE: VA .049 MkII RC
That sounds very similar to my own results when I ran mine a season or two back. I was running with an RC carb that I got from Larry. But as he warned the air bleed not being adjustable made for a very poor idle. However it started easily and ran strong with about the same numbers as you on my 5x3 Cox grey (if I remember rightly).
I was running the VA back to back with a Medallion RC engine and was delighted at the easy and nice idle of the Medallion. I came to the conclusion given the problems with the VA muffler (stupid spring clip) and issues with the carb and from the relative ease of idle and transition with the Medallion that I was going to try making a new muffer with an integral exhaust valve for the VA and combine that with a moderatley long fixed opening suction venturi instead of the carb.
However like many of my projects.........
RE: VA .049 MkII RC
Heres some No's I saved that from memory CP posted,
COX TD049
5x3 COX 22,000
6x3 MAS 16,000
5.7x3 APC 20,000
5.5x2 APC 21,500
AP
5x3 COX 20,000
6x3 MAS 16,300
5.7x3 APC 19,200
5.5x2 APC 22,500
AME
5x3 COX 21,200
6x3 MAS 17,900
5.7x3 APC 21,200
5.5x2 APC 24,000
BigMig is about - 1,000RPM from the AME
My own Bigmig 061 clocked 18,700RPM on a MAS 6x3.5 cut to 5 1/4" an 24%Castor,20% Nitro fuel.
Stewart
COX TD049
5x3 COX 22,000
6x3 MAS 16,000
5.7x3 APC 20,000
5.5x2 APC 21,500
AP
5x3 COX 20,000
6x3 MAS 16,300
5.7x3 APC 19,200
5.5x2 APC 22,500
AME
5x3 COX 21,200
6x3 MAS 17,900
5.7x3 APC 21,200
5.5x2 APC 24,000
Stewart
RE: VA .049 MkII RC
Stwart, your memory is better than mine! The results with these little engines is subject to this or that, MJD. Your results with the VA are good enough to go out and have a good time with, that's for sure. I would expect that it will continue to get stronger with time. I bet Larry gives them a flip or two before sending them out the door, just to make sure they feel right. You should see the VA run with a C/L venturi and a little combat prop! Time to get out the ear plugs!
On a very good day, a TD .049 can turn a 5x3 prop 24,000 rpm on 40% nitro. This was with the high compression KK head and a 5x3 prop that hadn't been checked for true pitch. The older those rubber props get, the more the blades flatten out with rpm. I have seen a new first generation AME turn the same prop over 25,000 rpm, but it couldn't turn the trick twice in a row without seizing up. A FORA .049 doesn't turn a 5x3 much better than this, but it does it so easily on sport fuel. To wake up a Fora, you got to get rid of some prop diameter.
Comparing your carbureted VA to these WFO engines isn't fair, but I just want to let you know that if you ever want to see what your VA can do, don't be bashfull because it is just loafing at 20,000.
RE: VA .049 MkII RC
ORIGINAL: combatpigg
I believe there are a few more rpm to go yet, I can see it hitting 20k or maybe a hair more on the Cox fuel, once I get 3-4 more runs on it I'll go to 30-35% nitro and a 4.5-3.5 or 4.2-4 prop. I'd like to coax it up to the 23-24 k regime.
The muffler on this one is not spring mounted, it mounts with a pair of machine screws. I was running it muffled on these runs. probably a good idea at 10am on a Sunday morning in a small village of 12 houses and a church.
RE: VA .049 MkII RC
ORIGINAL: flyinrog
Mine is the .06 VA, its rear exhaust and the muffler screws on, havent fired it up yet,maybe this spring...Rog
MJD
RE: VA .049 MkII RC
Keep in mind guys that all the VAs should be run with a castor based fuel. A blend is OK but the more castor the better in my experience. Otherwise, like Cox, if you don't, the rod will wear too fast at the piston end.
I'll be making up a proper, 1cc VA using Norvel parts some time this winter.
I have still new, never run, 5 of the VA MK1s. Three of these are nickle plated all over, inside and out. This is the way they did it at the very beginning.
These may have collector value but I went and trimmed off the intake to all of them to take throttles . Dang.
RE: VA .049 MkII RC
ORIGINAL: 1705493-AndyW
MJD
RE: VA .049 MkII RC
ORIGINAL: DeviousDave
The VA motors are timed a little too wild for a 5-3 prop. Need to go a lot smaller, with big hits of nitro.
MJD
RE: VA .049 MkII RC
MJD,
I was referring to the MK1. My experience, (for sport flying anyway) is that the MK2 RC version does well on a 6 X 3 but the MK1 likes smaller props. Keep in mind, this is sport, RC.
But you also need to keep in mind that not all props are created equal even in the same size.
Look at a 6 X 3 in a Cox, a Tornado and an APC.
The first has huge blade area with a square tip. The Tornado, much less with a rounded tip. The APC is the dinky one with a knife like blade and a pointy tip.
The interesting thing is that on some applications, even though the Cox loads the engine more and reduces RPM, in the air it generates more thrust. That is one very efficient design. I wish it was available in all sizes up to gassers.
Also, it's been my experience that if the Cox 6 X 3 is too much load, better to go to the Tornado 6 X 3 to reduce load rather than a 5 X 3 Cox. Don't know why, despite the preceding, it just works that way, for me, for sport RC.
Another point. One feature of the Cox props is that the flat bottom airfoil is carried all the way to the hub. I've applied this feature to a variety of props from APC, the Tornados and some Taipans and in all cases, I get from 500 to 800 boost in rpm.
RE: VA .049 MkII RC
MJD,
MJD,
