How to start Cox engines
There are two essential elements to starting Cox engines. (1) a hot battery, make the glowplug glow at least orange. (2) a head prime. How much varies with individual engine. How much crankcase prime is needed also varies with individual engines.
If there is no starter spring, there is: (3) after head prime, turn the prop backwards to vertical, attach battery, hit propeller forward with your gloved finger. Flipping a Cox engine is an exercise in frustration.
If you fool with your Cox engine a bit following the above principles, you will soon get one hit starts almost every time. Reliable is good!
RE: How to start Cox engines
I just picked up an old Cox Cessna 182 Skylane (to replace the one I flew like I hated it, and did at the time) with an engine that looks like it hadn't been started up in a decade. After a squirt of fuel in the cylinder and a few lubing up flips, it fired right up!! Now,,,,, the trick is to get it to run at the field (seems they never will for me!)
NE
I think this is a handy tip as the amount of castor needed to run these things is also a good plugger upper if they sit for long... I've seen it get plastic-like and cause sealing problems in the reeds even. Ross
ORIGINAL: Falco250
I spray automotive throttle body cleaner through the needle valve barrel if the engine has not been operated in a while.
I'm sure this isn't news to most but.....once the engine starts, but suffers at low RPM, a quick verical shake of the nose of the model will bring it up to speed.
Kirk
Kirk
GA
Jim, there is an excellent article on my site by Larry Renger called "Care and Feeding of a Small Engine". Given what they need, my Cox engines are the most reliable in my hangar. Better even than the big engines!
ORIGINAL: ptulmer
MJD
I have to agree on the hot battery. I always use four D-Cells. I buy cheap batteries at the dollar store. When every thing else is right and a Cox won't start check the battery. I had a few old glow plugs that I thought were bad until I connected them to a powerful enough battery. The art of the prime is something that can be developed with time if you pay attention. My "favorite" reedy usually starts on the first or second flip.
