Crash sale for Wednesday
MD
Well Hobby Lobby is spaming a plane for $20.00 tomorrow (cheaper than air hog) but no disclosure yet; will have to wait till the morning to find out if it is worth the while.
MD
RE: Crash sale for Wednesday
Well the Cat is out of the bag:
Exciter Profile Plane - 34-1/4" wingspan, 34-1/4" long, 239 sq. in. wing area, 16 oz. flying weight. Pattern style airplane has a slick pre-decorated laminate surface that adds to the overall stiffness of the foam. Parts are laser cut and pre-notched for easy alignment and accurate assembly. Most components are surface mounted for easy access and cooling. Wire landing gear has a wide stance for good ground handling, and easy takeoffs and landings. Large control movements make "Exciter" a highly aerobatic airplane. With smaller control settings the airplane becomes an aerobatic trainer. Long tail moment helps airplane smoothly track through large maneuvers. Build time is about 4 hours using a hot melt glue gun (available from a craft store). For 4-Channels: Ailerons (2 servos), Elevator, Rudder and Throttle.
http://www.hobby-lobby.com/exciter.htm
