Newbi>>how To Keep The Cox .49 Engine Running.....baby Bee
ok i have a cox baby bee .49 engine and when i start it it just shuts off it like fuel is not getting into the engine i dont think i have the proper needle valve setting correct on it can someone please assist me in getting the engine running continuse
FL
shoulda got a norvel! just kidding, it is not getting fuel for one of several reasons. close needle gently, then open 2-1/2 turns, try it there. If it is a used engine, old fuel and crud might have accuulated in the venturi or the reed might be stuck. That would require disassembly and cleaning; I use denatured alcohol for cleaning. Disassemble CAREFULLY over a paper towel in a well-lit area!
now, the cox engines are fairly simple, but sometimes finicky. Keep at it, and don't give up! Troubles just make it more rewarding when that engine sings!
CoxEngines
2 strokes have to have base compression to start. take the head off - flip the prop to see if it make a little put put noise when it turns if yes the reed between the gas tank & the rear of the crankcase is sealing --is ok -if not take it apart & clean it up. Carefully! the slightest damage or trash will keep it from sealing motor won't start.
