.049 size plane - flight pack?
WA
Now that I've ordered a few Cox .049 sure starts, I'm pondering a build.
What kind of servos are required for planes this small? HS-55 sufficient? Maybe the Hitec Micro Pack Micro 05S w/ 3 HS-55 Servos flight pack? What kind of Rx battery pack do folks run? The Berg microstamp looks nice as well.
somegeek
somegeek
RE: .049 size plane - flight pack?
Mini or micro.
HS-55 sufficient?
Yes.
Sure, this is a good choice. It's 9 or 10 grams and full range, just the ticket.
General sport use - 225-270mAh NiCd is good. 300mAh NiMH too, if you have a means of charging it properly.
The Berg microstamp looks nice as well.[/i]
It is indeed. But you're fine with the 05S unless you are getting critical for space and the last 5-6 grams count.
MJD
Mini or micro.
HS-55 sufficient?
Yes.
MJD
My Feedback: (10)
Shoot, you guys cut the battery juice way closer than me. I like the radical rc 740mah Nimh. No worries on my end!
I also like GWS stuff Rx and servos. Those of you who don't can do things to yourselves that your mom wouldn't approve of.[X(]
The berg works good too.
WA
Thanks for all the replies.
Who makes these smaller Rx packs?
ORIGINAL: MJD
ORIGINAL: somegeek
ORIGINAL: MJD
As flyinrog mentioned above, radicalrc.com. Excited to read the replys, you may have overlooked it.
WA
ORIGINAL: redbird340
I see a 250mAh pack on their site which is 1.55oz... for less than 1/2oz more Tower has a 750mAh pack at 1.9oz.
somegeek
PA
I picked up a few of these last week:
[link=http://www.radicalrc.com/shop/?keywords=370+nimh&match_criteria=all&search=Search&shop=1]Radical RC 370mah NiMH[/link]
More juice than the standard 270 mah NiCDs at half the weight. $13 each with connectors. Unlimited vertical - PRICELESS!
EG
EG
ORIGINAL: eroc144
EG
EG
I use my Futaba wall wart charger for my nimds and nicds both
OH
I don't mean to but in, but I was thinking with these small planes using 9 gram servoes, a reciever that weighs less than 1/2 oz. I've been using a 700 mah pack that weights 1.9 oz.. I have several 220 mah flight packs that I could convert to reciever packs. My question is how much flight time can I expect out of the 700 mah or the 220 mah before recharging. I'm only using two servos.
EG,
Thanks a bunch for the post on the 370pack and the R-RC webside. I've been building allot of 1/2a as well as 1/4a stuff lately and have been looking for some lite battery packs.
chuck
chuck
WA
Thanks for that eroc144! Looks like RadicalRC has some micro switches as well. Nice cheap shipping too!
flyinrog - looking to build a something sporty with ail/rud/ele.
somegeek
somegeek
