cox fuel tank
My Feedback: (12)
cox fuel tank
ON the cox .049 dragon fly engine/tank the black one have a gasket on the back cover or did it not leak by tighten the four bolts that held the tank.engine to your plane or do you need to seal it with something
My Feedback: (12)
RE: cox fuel tank
Have you had or tryed a PRESSURE BLADDER from texas timers the reason i was going to use the .049 dragon fly because it had a build tank on it.The 1/2a steath sport i have does not have much room up front to use a TD.049 i really wanted to use not even enoght room for a 1 oz round tank and read that a pressure bladder could be put in the back of the plane were there was room and holds enoght pressure to keep a TD fueled even inverted can hold 2 0z or more fuel thanks
MO
RE: cox fuel tank
Try smearing some hi temp gasket sealer on saran wrap cover with an additional sheet of saran wrap and GENTLY press the part the gasket goes on to make an impression. don't squish it all out though. let it cure and cut it out later. Or just use a tooth pic and seal it with the same sealer. the stuff should stick well enough to be permenent but it will make a good seal.
