049 and 09 replacement heads???
MO
Is the nelson plug the way to go on both of these? I read the std. plug conversion heads are OK but the Nelson plug conversion keeps the rpms up better. What is the tap size for the nelson plug? I want to save my TD heads for special occasions. Thanks in advance.
RE: 049 and 09 replacement heads???
11/32x32 is the thrd for the nelson plug...that is an odd size, can be found though at a bit higher price than normal, the trick is the seat on the end of the plug, it isnt a matter of just drilling a hole and tapping it. you have to have a seat at the bottom of the hole for the plug to seal, the plug does not use a washer to seal against
fire up that old dusty lathe and have a go at makin one
I dont think so, not enough room, as I dont think the material would be thick enough, I never tried it, you can buy a head from Galbreath for 10 bux, not worth the ffort to do anything else. now the .09....maybe but I doubt you could there also, the depth of the hole to be tapped is very critical, not like you can do it on a drill press. Better to make it on a lathe or a mill.
TX
If I just wait long enough,
One of these 1/2A machinists that hang around here will buy a spool of platinum wire & start Re-Fillimenting old cox heads.
MO
I emailed Larry about the 09 head, and will pick up the 049 conversion head...after Christmas if it doesn't show up in my stocking
OH
You can go to this website and buy a nelson conversion Head http://www.kittingittogether.com/ Or you can get conversion heads at http://www.mecoa.com/acc/adaptors/index.htm
ORIGINAL: OzMo
Can a burned out Cox glow head be drilled and taped to have the bottom seat?
http://www.rcuniverse.com/forum/m_45...tm.htm#4533758
The depth of an .049 plug is just right. I haven't done an .09 plug yet but it the plug body is deeper at that point, you just have to use the mentioned drill as a go, no go device. Then, you'll have to carefully use a drill bit to trim the top of the plug to allow the turbo to seat down far enough.
