Ailerons?
RE: Ailerons?
Go with the outboard. Unless you're doing 3D airflow from flying will far outweigh propwash. Plus, outboard ailerons have much better leverage than inboard ones. Also, outboard ailerons take advantage of the speed differential when turning.
NC
RE: Ailerons?
What he said. I'm building a Prime Stick now with barn door ailerons. The wing looks much more "real". I think they went to strip ailerons because it was easier to hook up.
Personally, I think strip ailerons may add unnecessary extra drag. Something to think about when you are building the ultimate Reedie Racer.
Gee, I just looked at the list of who's online and it looks like the whole gang's here. . . So Happy New Year youse all!
RE: Ailerons?
Hey Stang, nothing in particular, just the usual flood of ideas that I half ass finish until the day before the reedy race, then turns out badly...so I end up yelling at people to shut up and start your engine...I'm gettin real good at that......Rog
RE: Ailerons?
ORIGINAL: combatpigg
Vic, why not scale down a Predator or Dominator to about 150 sq inches? Move the wing back an inch to account for the lightweight 1/2A engine and yer in.
MO
RE: Ailerons?
Some pylon planes have only one aileron for turning only one direction while racing hmmmm. the outside wing in a plane flying a circle always moves faster than the inner wing so go for the fast wing for control. I believe that is the theory but I'm speaking off the top of my head and its not even to good for growing hair. Don't forget about mechanical exponential on one servo aileron set ups.
RE: Ailerons?
I don't know of anyone who has tested the single aileron on either wing panel for the best results. The outer panel will have more drag when the aileron gets deflected, so the nose should want to stay up in a turn. I have a dual aileron 1/2A pylon racer that dips the nose in the turns and am almost ready to roll out a single aileron racer that is almost identical. Hopefully it will want to run the course with less input.
My Feedback: (10)
RE: Ailerons?
Bob didn't have any problems with his planes but I did. You can see the little pc of cardboard I put on the aileron to get enough roll to make a turn for the race. I really struggled with it that day. I need to go back and extend the link inside to make the throw moment longer.
If I was doing a hundred miles and hour this may not have been such a problem.
RE: Ailerons?
CP the one that dips the nose may have too much fin area.
The aileron will only produce drag when deployed for rolling into or out of the turn. Once in the turn it'll be pretty much back to neutral. But I tend to agree that the outer panel would be the right place since it would tend to yaw the nose out and up and somewhat avoid the tendency to dip the nose. Running one aileron would also be a good way of avoiding the sensitivity at higher speeds that likely often results in over control.
RE: Ailerons?
The drag from the outer aileron [entering the turn] might be able to "cock" the nose of the plane enough to maintain a better heading through the turn. My "nose dipper" plane actually flies the course pretty well but it does leave a nose down silouette at the far turn. There are so many other factors that come into play, including how precisely built the plane is, CG, etc.. The electric racers tape the outboard ends of their ailerons to eliminate buzzing and to smooth the plane out. These guys are doing over 100 mph on a short course and they are "all over the place"
