LMH .061 Norvel heli to plane?
have looked up the parts and when I convert my heli to an .074 I will have the .061 leftover and can for $35 convert it to regular plane rc motor, need carb,muffler, and head, anybody got any of these parts, they want to part with?, locked up a .o49 to .074? I think its the same carb,, will pay for it........ but $25 for a carb on a $45 engine is a little steep...........oh well, if ya got it let me know.......thanks .. Rog
.061 head
.061 muffler
.049.-074 carb (think they are all same)
.061 head
.061 muffler
IL
I just picked up slightly used a LMH .061
Plan is to trim the heat sink head down to 3 or 4 fins
and to purposely use the throttle muffler. linkage maybe
an issue though...
FWIW
The prop screw/ clutch shaft pitch is also different than the aircraft motor.
nitro joe
P.S. Anybody now if the port timing is the same as the BigMig?
an issue though...
FWIW
nitro joe
My Feedback: (7)
TX
for a cheap conversion,,
use a cox .049 head
dig through your small machine bolt drawer for a prop bolt.
cut off and patch the throttle tube on the muffler.
I did this same thing, and got a great little engine for my glider,, the heli muffler acts like a slightly "tuned" pipe,, and gives a great mechanical seal so that the plane stays cleaner.
use a cox .049 head
