servo arms
servo arms
I've got several old Airtronic servo's that I used 20 years ago and I've rewired them for the new radios. The problem I have, I'm running low on servo arms. The new arms won't fit. Is there anyplace other than ebay where I can still buy them? I beleive the new ones are white and the ones I need are black. These servos, back in their day were mini and standard. Any ideas where I can get some?
RE: servo arms
You're just not going to find a supplier that has that sort of stuff that is specifically for your old servos. Some new ones may fit but it's pretty much a trial and error sort of search.
In the meantime measuring the diameter of the output stub and telling us how many spline teeth there are on the stub may inspire someone to check out their own servos and let you know if there's a more modern option.
You think you've got problems? I've got some old Dunham servos that I put together from an Ace RC kit. The arms use a square socket. Just try to find THOSE arms....
