˙˙˙˙˙ puɐ pǝʇɹǝʌuı ʎlɟ ɹǝʌǝ
My Feedback: (98)
RE: ˙˙˙˙˙ puɐ pǝʇɹǝʌuı ʎlɟ ɹǝʌǝ
I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdanieg. The
phaonmneal pweor of the hmuan mnid Aoccdrnig to rscheearch at Cmabrigde
Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the
olny iprmoatnt tihng is taht the frist and last ltteer be in the rghit
pclae. The rset can be a taotl mses and you can sitll raed it wouthit a
porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by
istlef, but the wrod as a wlohe. Amzanig huh?
Ya'll knock this off, I'm on my 3rd beer....never lost power, but I tend to pull up when anything goes wrong(Bsarge pointed this out to me and he's right), and I have lost more than one plane pulling up when inverted.....and I also look like I'm fly fishing while all this is going on........Rog
I've harped about this before, because I've done it to myself when I knew better. If you fly a plane inverted with perfectly neutral trim [meaning with no thumb pressure maintained for level flight], it is easier to forget which way to move the stick when the time counts. If you fly inverted with some forward pressure on the stick, I think that is a built in reminder for "which way is up". Practice each flight with an equal amount of right side up and inverted flight [up high] and it will eventually get burned into those brain cells. It might take many, many flights. Once you think that it has become second nature, then trim the model out for a neutral stick both ways and go enter the limbo contest.
ORIGINAL: DeviousDave
I read once that we don't read words as much as recognize them..
ORIGINAL: lildiesel
There's a lot of research that's been done on that -- the simplest explanation can be found in the recognition of the shapes of familiar words. That's why it is easier to read text in Caps and Lower Case or just in lower case than in ALL UPPERCASE.
Ooops.. shhhh [sm=redface.gif]
When I first read one of those scramble letter thingies I was amazed.
Anyone else ever had a plane that flew the same way right side up as upside down? I had built a few Aerocraft Snappers, and the third one flew perfectly level when upside down. Can't explain it other than the various trim factors and a bigger prop (this one was leccy powered).
TX
Hots with a piped Fox .45.Point and forget.Ultimately
that is what happened.My limited skills require me to
trim like Mr. Pigg says.A little reminder.
Ralph
Ralph
AK
Howdie gents, DeviousDave, Yes, Rattel came out that way. Flys the same ether way. Most of the time its a balence thing. if it takes trim to fly level then she will not hold true inverted.Aoa comes into play to. A well balenced plane is a joy to fly ether way. And a fully symmterical airfoil helps to. hkbii.
AK
Thanks CP. she now has a Ap .061 on her. I'm haveing a hard time waiting for the weather to let up so I can get her back in the air. The lower I get the dummer my thumb gets. hkbii.
ORIGINAL: combatpigg
Indeed you are so right about the practice and many flights to fight the natural (for me) urge to simply yank back on the stick.
Robert
My Feedback: (98)
ORIGINAL: build light
Robert
Robert
My Feedback: (98)
planes with seams facing into the wind to do much flying.
