what sealant for tanks??
MO
Hi guys,
I'm working on the Sure Shark tank and I can't remember if high temp silicone will work on glo fuel tanks.
I posted this pic before it shows the alum vodka bottle I am using for a tank.....2oz. ...yep I like LONG flights
the alum bottle is no heavier than a dubro 2oz tank as far as I can tell.
RE: what sealant for tanks??
SNAP!
I'm building a Sure Shark at the moment (still got glue on my fingers right now from it) and have been thinking about the tank. I was planning to use a Fuji film cannister. There is juuussst enough room for one as long as the openings are made in the bottom of the cannister and the lid is towards the rear of the plane. I am seriously thinking of using some rubber grommets with maybe a little silicone sealant. Might knock one up to test the idea (I've got about a dozen of these empty film cannisters lying around). Not sure what type of silicone I'd use. I've got access to several different types - red hi temp, white bathroom, opaque general purpose, clear etc. I've heard the best way to do the fuel line holes is to melt them with a soldering iron; dont drill them because the plastic will crack around the hole.
I think if one type of silicone works, they all will work. After all, the main ingredient is the same, it's only addatives that change it from hi temp to batthroom type.
ORIGINAL: OzMo
Hi guys,
Hi guys,
The tanks seal great on their own. Done right, the fuel inlet/outlet don't even require adhesive. Three methods have worked fine for me in the past: 1. drilling a hole 1/32" smaller than the tubing used for the inlet/outlet nipples, then press fitting it in. 2. drilling a hole large enough to accept a section of silicone line, inserting the line a short ways in, then inserting a section of brass or nylon tubing into that so that it swells the silicone tubing outwards tightly into the walls of the tank. 3. same as #1, but using a section of 1/8" OD polyurethane tubing (as used for small pneumatics etc.) as the inlet and outlet nipple. Silicone easily pops overtop of that.
Drilling is done with sharp bits at fairly high rpm, you want a nice clean cut. Alternately, find a piece of brass tubing that is undersize, and heat it in a torch, then push it through. It doesn;t have to be cherry red, just hot.
I strongly suggest chewing up a film can or two experimenting with your techniques.
Due to the force required the tubes don't budge in the tank. Some folks wrap electrical tape around the lid-can junction for security in a bumpier than normal landing.
MJD
I've never built one but will in the future so I've been listening to all ideas. I've heard that if you make the hole in the canistar small enough where the little piece of silicone tubing is somewhat tight going in, and then you push the brass tube through it, the tube expands the rubber tubing gets tight against the burned edges in the canistar. Sounds good to me, let us know what you do. Terry
Film is dieing out on us. I just want to remind you all to drop by your local film processing shops and pick up your lifetime supply of Fuji containers soon while you still can. And they come in handy for a lot of things besides fuel tanks so get lots.
OH
I have used the fuel line tubing like Terry said in post #5 and it has always worked for me make the hole just a liffle smaller than the fuel line and just a little bigger than the brass or aluminum tubing. The tubing will press the fuel line snug against the hole and make the seal for you.
I use the tubing method (drill rather than burn) to cut holes in the bottom of the tank and tubing inserts to keep the tubing from collapsing where it passes thru the bottom of the tank. The tubing seals well and being softer than the tank plastic, it does not seem to cause stress cracking as much.
The tubing is silicon insulation from 14 AWG battery wire. I had gone to the LHS to get some small silicon fuel tubing, but when they were out, decided to try the insulation as a last resort. It has worked well and is so flexible, I use it instead of fuel tubing.
ORIGINAL: BMatthews
ORIGINAL: OzMo
OK so .... does silicone hold up to 1/2 A fuel? I will grab a stash of fuji cans
Robert
MO
Cool
Thanks I will install the tank now! Can't wait to fly this bird.
I have a shark theme greeting card I want to use a photo shopped(mirror image) version of on the fuse sides.... we'll see if it works out. I plan to make a color set of mirror copies (lighter than the greeting card) to apply to the sides of the fuse. I will spray paint the areas it won't be on first then stick on the shark images then shoot with clear poly urethane for fuel proofing. should be a little different . If it ain't butt ugly I'll post a pic.
I wonder how that clear spray that is used on auto electrical spark plug wires or electronic equipment would work to fuel proof a plane? Anyone tried it? Terry
ORIGINAL: tewitt1949
Quote by tewitt1949:
"I wonder how that clear spray that is used on auto electrical spark plug wires or electronic equipment would work to fuel proof a plane? Anyone tried it? Terry"
When all else fails, Lusterkote works every time.
Robert
Robert
Build Light, Someone here said that the lustercoat will come off on the rag, as if it isn't fuel proof. I don't know, but maybe lustercoat has to set for 7 days like Krylon plastic type paint. If you put fuel on it too quick(before 7 days) it will disolve the paint. Terry
ORIGINAL: BMatthews
